Newbie needs help please! 2018 320S Outback. Trying to test Alde for the first time to make sure I get hot water. Haven’t even turned on the Alde yet... Filled fresh tank 75%. When I turn on the pump water flows out below the (yellow flapper) safety valve (drain D in the pics). With pump running I’ve opened sink and shower valves one at a time to expel air, water keeps draining from safety valve. Turn off the pump, water quits draining. Without pump running I’ve opened the yellow safety valve (no water drains) and closed again (several times). Pump on again, water pours out. What am I doing wrong?
Later while filling tank again I heard water dripping from the very back of the trailer. Water came out to the right (passenger side) of the license plate! It quit when I quit filling (fresh tank now 88%). With pump on, water drain from safety valve. Looking for help and thank you.
; Westlake, OH
