Attaching a tarp for an awning to the keder rail
LittleBoyBlueLittleBoyBlue Member Posts: 22
I originally attached a tarp to the keder rail of my t@b 320 using some poly rope with a knot that fit in the slot.  It worked fine but wanted to add a larger tarp to connect to my new Clam screen room to the t@b.  This time I found that using some 1/4" nylon clamps from Lowes fit perfectly in the keder rail.  I attached the clamps to the tarp at the grommets with a nylon cable tie and it worked perfectly.  Part number from Lowes for the clamps is Item # 139498 Model # 881298 Hillman 12-Pack Full Clamp. $1.08 for 12 of them.
Mike & Sara Ross - Panama City, Florida - mrosspc@gmail.com - 2015 Toyota Sienna - Little Boy Blue - 2018 T@B S
