Tail light issue
lkc001
Member Posts: 877
When doing my pretrip inspection this weekend my left tail light had 3 LEDs that weren't lit up but the rest of the LEDs in the light were OK. I thought I was going to be replacing a tail light. When checking at the campsite they were all on & functioning properly. Any ideas on what's causing this & what I can check for? I have not opened up the tail light housing.
2018 Tab 400
Only a guess,
intermittent electrical contact to 3-LED inside the tail light housing. Those light could be flashing on/off while driving.
Believe the tail light assembly is a sealed unit . . . no owner access to the inside LED circuit board. You'd have to cut it apart to attempt a DIY fix.'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,180 -
Or just replace the entire tail light unit.
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
Typically, if a few LED’s go out, the rest will follow soon. @Denny16’s advice to replace the light is good advice.Verna, Columbus, IN
Thank you all
2018 Tab 400
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
