Deb55 said:We have both the MPPT smart solar and the Victron battery monitor installed in our 400. The Victron battery monitor is installed on the wall next to the wardrobe, above the light switch for the bedroom. I can connect to the battery monitor from inside the house, but I have to be quite close to the camper to connect to the smart solar. I think I set them up in a network, but I admit to having no idea what the purpose or advantage of a network actually is--if someone could explain it (simply) to me, I'd appreciate it!
Remove the screws on the radio’s front panel, then pull it straighten out, until the backside gets to the opening then pull the right side out first, then slide it tomthe right to get the wire harness out from the left side. You have two wire harness, one for the speakers with unused wires in it, and one for power, unplug both, then you can sit the radio on the bunk. Now you can use the hole left by the radio to get your hand and the backing nut for the monitor installed, and pull the wire for the monitor in from the back side.Tundra57 said:@Denny16 how do you get the Jensen out?
Given the fact that the display itself is almost useless and I only access it via the App on my phone I just mounted it under the bed near the batteries.Tundra57 said:Im about to install a BMV 712 in my Tab. My options for the BMV display is either on my new psnel under the three way fridge, or over the lighting panel bt the door. How far away from each other can the BMV and smart solar be and still get Bluetooth comms to form a network?
Yes, and much more!!Tundra57 said:@m_lewis and @Michael49, both good options. So all features and settings on the display are available with the app?@m_lewis, why did you have to remove the microwave? Was that to get behind the dispay to tighten the back nut?
