refrigerator shelf in the 400
Has anyone removed the refrigerator shelf in their 400.  If so how, seems like it should come out.
Happy Trails,
Phil & Anita - Driftless: 2018 T@B 400/2015 Ford Explorer
  • Verna
    Verna Member Posts: 6,876
    @driftless, if no one else answers you, try sending an email to tech@nucamprv.com. He’s a very knowledgeable young man with the entire factory at hand as a resource.
  • driftless
    driftless Member Posts: 135
    Thanks will do
    Happy Trails,
  • atlasb
    atlasb Member Posts: 584
    The shelf does come out if you will press the white plastic fixture at the bottom side, on the right side of the shelf. It should pop up and then you can remove it.   It kinda holds the shelf in a recessed position.  We remove it if we are carrying taller bottles and replace it if we do not need the extra height.  I put it in the closet if it is out.  Nice to be able to remove it and replace it.  You might have to experiment how it pops out but it will.  Sort of like removing the circular screen on the fantastic fan.  It will come out!
  • driftless
    @atlasb Thanks that is what we thought just didn't want.to break something.
    Happy Trails,
  • DABWCA
    DABWCA Member Posts: 70
    I was really happy to see that the puzzle of removing this shelf had been solved. But I've now pushed hard on this fixture every which way and have about given up before I break something.  I'd be grateful for some tips as it sounds easy. Do I push in, up, down?  How hard. A photo is attached unless I can't figure out how.
    David -- Saint Paul, MN
    2015 T@B-L "Silver Dr@ggin" towed by 2015 Kia Sorento V6 "Don Poulan"
  • DABWCA
