refrigerator shelf in the 400
driftless
Member Posts: 135
Has anyone removed the refrigerator shelf in their 400. If so how, seems like it should come out.
Happy Trails,
Phil & Anita - Driftless: 2018 T@B 400/2015 Ford Explorer
@driftless, if no one else answers you, try sending an email to tech@nucamprv.com. He’s a very knowledgeable young man with the entire factory at hand as a resource.Verna, Columbus, IN
Thanks will doHappy Trails,
The shelf does come out if you will press the white plastic fixture at the bottom side, on the right side of the shelf. It should pop up and then you can remove it. It kinda holds the shelf in a recessed position. We remove it if we are carrying taller bottles and replace it if we do not need the extra height. I put it in the closet if it is out. Nice to be able to remove it and replace it. You might have to experiment how it pops out but it will. Sort of like removing the circular screen on the fantastic fan. It will come out!
2018 T@B 400, 2017 Nissan Titan Crew cab -
@atlasb Thanks that is what we thought just didn't want.to break something.Happy Trails,
I was really happy to see that the puzzle of removing this shelf had been solved. But I've now pushed hard on this fixture every which way and have about given up before I break something. I'd be grateful for some tips as it sounds easy. Do I push in, up, down? How hard. A photo is attached unless I can't figure out how.David -- Saint Paul, MN
2015 T@B-L "Silver Dr@ggin" towed by 2015 Kia Sorento V6 "Don Poulan" -
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
