Drop in Battle Born Plan for Advice Please
kbdigitiqe
Member Posts: 163
Hey guys, 2021 320s BD here with built in solar and this is my plan after speaking with super helpful folks at Battle Born:
1. Drop in their 100ah LiFePO4 battery where my existing battery is up front the box
2. Add a Progressive Dynamics charger for the new battery under the seat by my existing converter (see pic below)
3. Plug in the converter with a low profile standard cord at the outlet right by the panel and run the cord under the precut gap in the wood work (see pic)
The question is 4. .. instead of fishing new wires from the new converter to the battery, I would love to "interrupt" the wiring that is currently coming out of the OEM converter that runs to the battery and just connect it to the new charger. Anyone see any issues there or any recommendations for figuring out and grabbing those wires? The labeling on the back of the OEM converter says the red wire "is to battery positive and for DC" so I'm not super sure what I would be disconnecting there?
Or, can anyone point me to a thread or advice on how best to fish a new two conductor to the battery location up front?
Thanks!
Thanks!
The wiring that goes from the OEM converter/power panel to the battery may also be the supply line from the battery to the converter. Break this connection, and your trailer 12VDC systems might not get any power from the battery to the trailer. Something you need to check first, you might consider getting the upgrade battery charger in the OEM unit.See last few posts in : https://tab-rv.vanillacommunity.com/discussion/11099/lion-lithium-batteries#latest
I don't know what power centers get installed in the 320s, but Progressive Dynamics makes replacement converters that fit in many power center enclosures replacing the existing converter. Check out: https://www.progressivedyn.com/rv/power-converters/inteli-power-4600-series/They have Li-specific versions. Then you can re-use all your existing 120V and 12V wiring.
Roger and Sue Hill | 2020 T@B400 Boondock (Cryst@bel) | 2022 Land Rover Defender 110 - P400 | San Juan Island, WA1 -
Yeah, I’m gonna call PD on Monday and see if they have anything compatible with the WF-8735-P (that’s what comes in the 320s). Otherwise going to fish new wires from the outboard charger to the battery - it seems like their unit only goes down to the WFCO™ #8935
Following. Are you adding more solar as well?0
