2021 320S Solar Option
Dale2012
Member Posts: 1
I am considering a new 2021 Tab320S. I see discussion of solar option on 320’s but no full description of the components included with a new 320 on the nuCamp site. Does anyone have a list of the components included with the Solar option?
Currently on the 320, nuCamp is using 105 Watt Solar panel (Previously used 130-watt panels), installed on the roof, one Victron Blue Solar MPPT 75/10
charge controller with a fuse, and wiring to connect to battery.
Where are you getting the info that it is a 105w panel? It looks identical to the 130w Sunflare they installed lasted year on my 2015.Denny16 said:Currently on the 320, nuCamp is using 105 Watt Solar panel (Previously used 130-watt panels), installed on the roof, one Victron Blue Solar MPPT 75/10
cheers2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
I'm still hoping I got a 130 but my size closely matched the 105
managed by VE Smart Network -
I saw it in several posts about solar here. But 130 or 105 watts is close to each other in charging ability.
I just repeated this question up top. Let us know what else you find out regarding 2021 components.
@GC3..ours is due in mid August from what I've learned...will let you know...Former 2017 T@G Max XL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
