2021 TAB 400 Mattress Orientation
Giota
Giota Member Posts: 59
Mitered corner only allows brown quilted side up. Is this correct? The prettier side (Beige Fabric) goes down? Hmmm, seemed backward to me, but maybe this is the correct orientation. What is the answer from our esteemed technical experts?
  • ChrisFix
    ChrisFix Member Posts: 743
    edited July 2020
    The quilted side is meant to be the 'top' on each of those bed cushions I believe the bottom is a more water resistant fabric to prevent absorbing any condensation that develops.
  • VictoriaP
    VictoriaP Member Posts: 1,496
    All the ones I’ve ever seen have been quilted side up. As with any mattress, looks are irrelevant once you put the bedding on it anyway, right?  ;)
  • Giota
    Thank you very much for these comments! I love this forum.
  • Denny16
    Denny16 Member Posts: 5,430
    Yes, mine came quilted side up.  That said, whilst the bottom cushion is fixed position wise, you have a choice of using the other two cushions cross wise as delivered, or switch the top two lengthwise, and eliminate one cross wise gap.
  • Lloyd
    Lloyd Member Posts: 34
    I was confused by this as well and even tried to apply logic–albeit flawed logic–by thinking that the mattress tags are always on the bottom side of a mattress.
    2020 T@B 400 w/ factory solar
    2015 Nissan Frontier SV, 4WD Crew Cab
    Manson, IA
  • ecstatic
    ecstatic Member Posts: 66
    Brown quilted side is supposed to be up.
    2020 T@B 400 BDL    2025 Silverado 5.3L V8
    Chili, NY
  • Denny16
    yes, the tags are on the only seam on the cushion, which is on the top, wrong way round.
