Solved! Want to install a lean to on side of 2018 320 s
Tilleo
Member Posts: 4
Problem I have is there aren’t mount on top of t@b any suggestions on what I could get to tie a lean-to too?
Check out the famous "Red Neck Porch." There are some other threads about how to attach a tarp or whatever to the keder rails of the trailer. I use something called a "tarp tracker" that slides into the rail and you can attach things to it.
Towed by 2014 Touareg TDi -
The keder rail (aluminum extrusion) that runs along the curve of the trailer roof is designed for attaching awnings. You can fabricate your own slugs to use as attachment points.San Francisco Bay Area
Thanks everyone perfect 👌 I have limited service, but very helpful thanks alot
One of the easiest ways is to buy a piece of the keder rail insert, cut it into tabs and either melt a hole thru the tabs or put grommets in them.2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL -
@Tilleo here’s my upgraded version of Larry’s Redneck Front Porch. I bought the 5/8 keder rope, sewed it to a tarp, used his idea of collapsible painters poles, used carabiners to tie the guy lines, used @Dalehelman ‘s idea of lag screws in place of tent stakes so I can drive them in the ground with my cordless drill.
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red -
Any how-to ideas on feeding the keder rope into the "c" channel? No room between the channel and the handle plate. Thank you.
Starting from the rear of the TaB, look for a widening/separation of the keder rail. That is where you start to feed the keder rope.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
