I have several questions to learn how others do things.
1. where do you put the lagoon table when putting the bed up?
2. How do you lock the propane/battery compartment?
3. Is going to two 6 volt batteries dramatically better than the single 12? We have solar.
4. Do you find the hum of the refrigerator distracting.
Pretty sure I will have more questions later.
2. We do not lock the propane/battery tub. Out tub sits about 4-5 inches away from the side of the camper, so there is no point. We store at a secured facility, so not necessary. When at a campground, it would be nearly impossible to remove our 100# battery sitting tightly inside a custom box. If someone lifts our cheap propane tank, well, they probably need it more than us😊
3. It really depends on where and how you camp, how many amps you use daily and how reliably you can recharge. If you camp in sunny weather, you can get by with a 100 amp battery and your solar. If you want a greater margin, go with the 6 volts as they will give you about 120 amps before you need to recharge.
2. No lock - I have heard that this may be code? of some sort because the propane is in there and there would be a need to access it quickly if there were a leak or a fire? (As I type that, though, to be fair the window in which that quick access would make a difference is so narrow I’d be using it to run away...)
3. Love our dual 6V setup as we can get away for a 3 day weekend without having to worry about how much sunlight we’ll have hit the solar panels. Our stock single battery was 84 Ah (so about 42 Ah usable), now we have 235 Ah (117 Ah usable) which is more than plenty.
Can you give me the details on what alarms you installed?
Thanks
To answer the original question, eat, sleep and wash up are a given...
1. We pull the table top off, then the L-shaped support, and lay both on the floor under the bed.
2. I replaced the tub latch with one that is lockable..
https://www.amazon.com/dp/B0011G6DP8
3. Yes. A battery with more Amp-Hours will help to get through cloudy/shady days with less solar, whether that's two 6V or a larger 12V. We got a single 12V 150AH golf cart battery that fits in a group 27 battery box in our tub (with modification for a new tray to hold it).
4. I've never noticed any hum from our Norcold frig.
We've slept in 34 states, 2 countries & counting.
