Air8 will not run off of a 15 amp circuit
jkjennjkjenn Member Posts: 6,413
As an FYI, the Air8 will not run off of a 15 amp circuit.
The good news is that is I now have family planning to install a 30 amp conmection as a part of their imminent electrical box upgrade and rewiting project.
  • ontheroadontheroad Member Posts: 485
    The 30 amp plug was being installed in the pole barn...thanks for the info..
    Former 2017 T@G Max XL
    2021 T@B Boondock CS-S
    2018 Nissan Pathfinder
    Ontario, Canada
  • ChrisFixChrisFix Member Posts: 741
    That surprises me. I can run my coolcat off a 15amp...and I thought the Air8 used significantly less energy.
    edited August 2020
    Our Air8 can run on a standard household 20A breaker (which would be rated for 16 amps).
    Since they are installing you a 30A service @jkjenn, ask for water and sewer connections while they are at it!  ;)
  • jkjennjkjenn Member Posts: 6,413
    No kidding!! Water is doable....sewer...we'll need to work on that. There doesn't appear to be a sewer cleanup anywhere on site. BUT, since the live in Ohio, the turnpike has free dumpstations every other exit, which makes it easy to dunp on my way home.
