We purchased 7 mm diameter marine rope and folded a blue tarp over the rope to make an awning for our T@B CS-S. It is Very Difficult to pull the "tarp wrapped" rope through the keder rail (we start at the rear and thread the tarp/rope into the keder rail from the bottom opening and then pull it up and over) but it catches on every screw head in the keder rail. It is even fraying the tarp when we pull it back out when we break camp.
Any suggestions? .. are we using too big a rope? Wouldn't a smaller rope just pull out of the keder rail?
**see our home-made extension poles, we copied this from a video on the T@B forum a couple years ago. The poles are made from pvc plastic pipes, drilled with holes so you can adjust the height. They are heavy duty and withstand wind and rain.
8.5mm / 5/16”. Use nylon rope when making your own cord for the rail.
Welded flap material for making your own visor, etc.:
https://www.amazon.com/Keder-8-5mm-Welded-Standard-Black/dp/B010G1AXZO/ref=sr_1_2?keywords=keder+rail+awning&qid=1560540184&s=gateway&sr=8-2
https://www.amazon.com/gp/product/B010G1AXZO/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Keder Rail “tarp trackers” for attaching a tarp or similar material to the Keder rail:
https://Kedersolutions.com
Keder Rail hangers (home made):
https://www.popupportal.com/threads/make-your-own-awning-track-hangers.63064/
You might be able to counter-sink flat-head screws to make the rail more usable. It might be a bit of a chore, but maybe worth it, for home-made attachments.
Depending on your skill set, it might be easier to sew on kedar rail edging material.
Tampa FL
I think that the problem here is that a plastic tarp wrapped around rope and then sewn down probably isn't very smooth. I think that it would be better to buy premade awning tape (https://www.sailrite.com/Keder-Awning-Rope-Tape) and sew the flap onto the tarp.
I sewed the Sailrite awning rope onto this inexpensive Walmart awning to attach it over my clamshell.
Tampa FL
