Ok... have towed for 4 years with a perfectly level trailer, and we still have issues. We (along with some other CS-S owners we have met at rallies) have found that when our hitch height makes our trailer perfectly level, we cannot put our hitch wheel on. We have a work around... we have to drive the back wheels of the tow vehicle up onto a 2x4 ramp, and then we can get it on or off. How bad would it be to raise the hitch height (thus not towing a level trailer) so we can get that wheel on and off easier? Thoughts?
0 ·
How much room do you need? The 1 1/2 of a single 2x4?
Oh...and Go Dawgs!
San Diego, CA
www.airbossone.com
And Go Cougs!
Just spit-balling here:
Could go the route of air shocks on the Silverado but not sure you'd get enough height.
Would something like this help? At least you're not locked in to one ball height.
If you only need an inch or two, perhaps something along these lines might work. I've found that if solid ground and you get a bit of leverage, you can roll this to verticle fairly easily. Paired with the ball mount above it may work.
I suppose just using the foot pad isn't a good solution for you. I've found I use the foot pad much more often than the wheel.
Let us know what you find out.
San Diego, CA
www.airbossone.com
Tampa FL
Not sure if this idea would give the clearance you need, but these long "coupler nuts" raised our jack about 1-3/4 inches. I did this so I could still use my drill on the jack after installing a storage box on the tongue (Dale Helman's jack bolt mod)..
I had to turn the post to the rear to get clearance for the drill after adding a bike rack to the hitch bar.
This arrangement works, but also makes me thankful that I didn't just cut off some of the bottom of the jack, because now I must raise it as far as it will go to clear the hitch ball when hitching up (at least with the flat foot plate that we use most of the time). We only use the wheels if we need to rotate the T@B around for a better angle at the camp site.
I have grandkids with me today... when they settle down tonight I will go measure from the bottom of the coupler to the ground when level as @Sharon_is_SAM asked. We did do the math on our coupler and ball height and are certain the rig it level. We did nothing to raise the Siverado from factory ride height... and yes we are raising the jack fully. Tend to agree with @AirBoss that if we tow tongue high (so wheel can be mounted), we'll introduce the potential for more sway (which we never have)... thus why we have just put up with our work-around to drive up on the wood blocks... but thought we would throw it out there to see what all of your heads together might come up with.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
So @S@Sharon_is_SAM - bottom of coupler to ground is 11 inches.
San Diego, CA
www.airbossone.com
You can see how puzzling this is. As you can tell, we have a workaround... but even today when we took it in to get new tires, we couldn't put the wheel on without using our little 2x4 trick. We also just kind of want to put it out there for others with the same issue. I remember telling @mtnlvr (aka "Evil Red Ridinghood") about what we did, and she almost kissed us... she (like we had) was keeping a small shovel handy and digging a small hole to make it happen. There are times you need the wheel on!
Question: you stated raising the drop to 4" will cause bottoming out. How so? On the surface it would seem if you raise the point at which the ball meets the receiver that would give you more clearance, not less...at least at the hitch point. Was it bottoming out in the rear of the trailer?
Thought about the taking 2"-3" inches off the jack? The pic showing you trying to put the wheel on would indicate that might work and be very inexpensive...assuming the jack is fully retracted. Otherwise, see my post above re: the Andersen hitch options. Gives you options.
Good luck...let us know how it works out.
San Diego, CA
www.airbossone.com
Looks like you have a bit of a pickle. Shortening the jack stand seems like a viable option, but sadly you can undo it without additional effort and/or expense.
Keep us posted on how you get the Two Coug's "hitched."
BTW, looks like we won't be enjoying the Apple Cup this year. Heavy sigh... :-(
San Diego, CA
www.airbossone.com
