My wife and I have a 2013 Ford Escape Titanium with the 2.0 Ecoboost engine. I assume it has the factory tow package because it came with a FoMoCo hitch and wiring when we bought it used in 2016. We've towed our T@B 320 all over Michigan and to North Carolina in 2017 without any problems. In the last year, it started acting up with with overheat codes from the transmission and some sporadic, rough shifting instances that went away. I bought a ScanGauge and monitored the temps during a camping trip to eastern Michigan in July. On the freeway travelling at 70 mph, I noticed coolant temps would rise rise to a range of 220-230 F. Trans temps would range from 215 to the 220s. Under 60 mph, temps would be 210 or below.
I took it to my Ford dealership and they've found no problems. They pressure tested the cooling system for 24 hours and recommended replacing the antifreeze bottle and cap because it was venting 18 psi as opposed to 21 psi per spec. After they did this repair, I took it for a test tow and coolant temps went above 220 F. I even weighed our T@B and it's 2,100 lbs with stuff in it. The funny thing is the standard temp gauge stays in the normal position and doesn't move up.
Has anyone had this problem or have suggestions? I'm not ready to sell our Escape because it's fully paid off and in good shape with around 80k miles. We're not using it a lot since we work at home.
0 ·
when towing drive at 60MPH, you know the system runs cooler.
it should also improve the MPG
and really is a bit safer.
Odessa, Fl.
Huntington LI
I have a 2013 Ford Escape Se Ecoboost 2.0 and yesterday and today was my first time towing my 2015 T@b 320 CS-S... It ran hot (below the 3/4 mark but never went above) while going 60 mph on some hills...
Did you every fix your issue, and if so, what did you do?
Thanks!
Pulling a 2016 Tab Max S
So is a flush the way to go?
There is a more controversial thought. There is a transmission oil cooler, either built into or in front of the radiator (behind the air conditioner heat exchanger). Transmission overheating will cause the engine coolant to overheat as the coolant radiator is behind the transmission cooler. The two possible directions are a transmission flush or a larger oil cooler. If you haven't been doing regular transmission flushes, I wouldn't recommend the first flush be after 70,000 miles unless the fluid is pretty clean and the right color. When overheated, the fluid turns darker. When things begin to wear out, the ground material shows up as cloudy fluid. At any rate, the transmission flush has pluses and minuses, making it a bit controversial, riddled with wives tales and opinions.
Good luck
"Just Enough"
