T@B 400 external lp connection?
CalvinHobbes
Member Posts: 6
We have a 2021 T@B 400 Boondock coming soon and we're looking at purchasing a camp stove for cooking outdoors.
I seem to remember that there's an external propane connection, but I'm having trouble finding out what it looks like so I can get the correct connector for a Camp Chef Everest 2X camp stove.
Can anyone help me out?
@VernaYes, there is one at the back, just behind and under the rear cargo door on the pax (right) side of the trailer, appears to be the same setup as the 2021 320.
It is listed on The 2021 nüCamp TaB 400 specifications sheet under Basic Package, and you can see it on the side view photo.
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0 -
This will help - https://tab-rv.vanillacommunity.com/discussion/11344/new-propane-port-on-2021-t-b-320
@CalvinHobbes
The 2021 T@B 400 has the propane connector at the back of the passenger side of the camper (similar to the 320 picture above).
You need to know that this connection is a "low pressure" LP connection - meaning it is already regulated pressure (from the regulator in the front tub).
If your campstove has it own regulator, that will need to be removed, and replaced with a quick connect adapter for a flexible gas hose to connect between the campstove and the T@B's connection.
2025 Honda Ridgeline Black Edition with Redarc Trailer Brake Controller0
