Air8 will not turn on.
NoVaGuy
Member Posts: 95
Connected to shore power. Fans work. AC will not come on. Am not completely level, but close
2020 T@B 400 BD Lite
Be sure your set point temperature is below what the Air8 control panel is displaying. (Currently, the temperature sensor is located down in front of the a/c unit’s intake.) Just as a test, run it down as low as it will go, which I think is 61 degrees. I have observed a bit of a delay before it starts as well.
Breaker popped. It is going now. I can’t wait for the upgrade
2020 T@B 400 BD Lite -
@NoVaGuy I’m curious... what upgrade?
2021 T@B 320S Boondock | 2019 BMW X3 M40i -
The AIR8 plugs into a conventional GFI outlet under the bed. Check to see if the GFI has tripped or the plug has come loose.
Edit. Sorry the fan would come on if this was the case.
@sptucker - the 400 2020’s have an undersized Air8 and Elwell is working on a solution.
https://tab-rv.vanillacommunity.com/discussion/10397/official-statement-from-scott-hubble-concerning-the-air8-air-conditioner/p10
Oh, right, I knew that. I got confused by the blown fuse thing...
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
