Today I did a Black tank flush.  I connected the water hose to the black tank flush nozzle on the brand new Nautilus panel.  I opened the black tank valve. Connected the sewer hose.  Turned on the non potable water from my storage facility.
Here is my question and problem:  why did the the water fill my fresh water tank and also flush the black tank through the sewer hose?  Should I be concerned black tank matter going into my fresh water tank?  Any ideas?
                2021 T@B 400, 2020 Audi Q5
Portland, OR
0 ·
I have the same model 400 as you, and the black tank rinse should definitely NOT be filling your fresh water tank.
There is a Nautilus valve configuration to "Power Fill" the fresh water tank from the white (left side) "city water" connection...but the black tank rinse and the fresh water are never intended to come together.
Are you certain that the fresh water tank was filled during the black tank rinse?
If you had a steady supply of water coming from your black tank drain while using the black tank rinse, it would indicate that it was correctly adding water to the black tank, not the fresh water tank.
There is no Nautilus configuration for rinsing the black tank. The dry camping mode was used during this rinse. The time I rinsed prior to this time I used the City water mode and there was no problem.
Portland, OR
The fresh tank drains slowly, and there is almost always some more you can drain by tilting the trailer in different directions.
The sound you hear with the black tank flush is probably the black tank filling...It makes a similar noise to power filling the fresh tank.
Unless you had gallons of new fresh water, I don't think it is being filled from the black flush.
Portland, OR
