Hitch ball size for 2021 320 CS-S?
jeff57jeff57 Member Posts: 28
I have ordered a 2021 T@B 320 CS-S and need to purchase an adjustable height hitch.
What is the hitch ball size?  Any recommendations for an anti-sway system?   Thanks!!
    The hitch ball needs to be 2 inches.
    What tow vehicle will you be using?  Most 320 owners do not require anti sway devices.
  • tabiphiletabiphile Member Posts: 468
    Congrats on buying a T@B.
    You will require a 2 inch hitch ball.
    An anti-sway system and an adjustable height hitch are arguably unnecessary.
    Hitch height should be a one and done set-up unless you are swapping TV's. Even then most would opt for the less costly option of buying a second drop and ball for the other vehicle over the added complication of an adjustable set-up.
    A dealer might try to sell you anti-sway just because they can but that does not make it either desirable or necessary.
    There is added complication and cost associated with these and no real need. The need to decouple it in order to back up (unless backing absolutely straight) should be enough to make you reconsider.
  • jeff57jeff57 Member Posts: 28
    My towing vehicle is a 2019 Honda Ridgeline AWD
    Your Honda is plenty to safely tow the 320 CSS TaB without a sway control device.  Not driving much over 65 mph will feel like nothing is behind you.
