Air 8 Bell Symbol
The Air 8 AC Control on my 2020 320S has a constant bell shaped Symbol.  Is that normal? Also, I'm confused by the "Timer On" clock symbol.  Is it on when it's steady, or when it is flashing? If it is on, how do I turn it off? The manual is very basic and unclear to me.  Thanks in advance!
Wisconsinites 2020 T@B 320 S - 2021 Dodge Durango GT Plus TV
    Looks like you have it on a timed schedule?
  • BaylissBayliss Member Posts: 1,471
    @MikeDawn265, I don't have the Air 8, but @jkjenn's suggestion is what I would assume as well.
    Check the owner's manual for the time-setting function/menu.  The timer (and maybe alarm?) settings are probably a sub-menu within those settings on the control panel.  The link below (by "The Air Force Guy") is good for general operation of the Air 8, but he skips over the "timer" setting.  I am including the link if you are interested in reviewing it.
    https://www.youtube.com/watch?v=0aC0Wu5XqI0
  • MikeDawn265MikeDawn265 Member Posts: 29
    How would I turn it off? I've tried unsuccessfully!
    I got it! I was not holding down the buttons long enough to enter the timer setting. I was in clock setting. Once I disabled the timer the bell symbol went away.  Thanks for the help.
    Don't have access but if I recall you hold the "Power" and either + or - button for three seconds or so to enter the sub-menu. I think the Power/+ combo is for day and time so perhaps it's Power/- combo for timer?
    Sorry cant' be of more help at the moment. Presume the manual doesn't touch on this? The manual for the Air 8 lacking in many ways...
    San Diego, CA
    www.airbossone.com
