Education on my Factory Installed Solar Panel
kimmerfnp
Member Posts: 19
Greetings
i have a 2019 T@b 320 that has the factory installed solar panels. I Was not provided any info on them so I feel lost. I’ve researched on this site. I think I knew more about this RV than my dealer... Can someone please educate me. Where is the solar controller? I haven’t dry camped yet but is there something I’m supposed to do to use it etc? I’d appreciate any info.
Thanks
Kim
Kim
With factory installed solar, nothing to do but use it. You should have the Victron MPPT controller, and you can download the Victron App for yiur smart phone you’re connect via Bluetooth to the MPPT controller, to make sure it is set for your battery type. There have been several posts here explaining how to do this.
Thx so much
What model 320 do you have? I might make a difference in where the controller might be. It will be a box that looks a like this...since every controller looks pretty much the same. As Denny said, find the Victron App for your phone and see what your panel and controller is saying.
Towed by 2014 Touareg TDi -
I believe the factory installed controller for the 320 is under the driver side bench. If you don’t have the Victron, you may have a generic controller. Check under the bench first.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Thx. I have the 320 S. I found the app and all looks ok. Haven’t located controller under benches etc. Thx for everyone’s help
There’s one bench that is screwed shut where converter is. I haven’t unscrewed That bench to see if it’s there yet.
That is where it will be, with the rest of the electrical system.
Of all the benches in the trailer, that is the one you must open. A whole world of trailer fun in there! And, toss the screw.
don Don’t forget inside is a high voltage, high amperage zone, be careful where you reach in and what you touch.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
