No red light on power cord
I read on another forum that there is a red light on the 2020 T@B 320. I see where that little light should be but as far as I can remember I have never seen it light up.There was also mention of a blue light at the other end and I am not seeing that either. Everything seems to be charging but should I be concerned about the light issue. I don’t remember reading anything about that in the manual and my intro at the dealers was no more than 15 minutes so this wasn’t mentioned. Thanks for any advice.
Kr@cken
2020 T@B 320 Boondock
2020 Subaru Ascent
Bainbridge Island, Wa
    Those LEDs do fail pretty easily. As long as you have power when you plug in the cable, I wouldn’t worry over it.
  • Lil_LucyLil_Lucy Member Posts: 82
    On our 2016 T@B 320, the blue light on the plug end of the cable quit about 3 years ago. The red light on the end that plugs into the trailer is still working (knock on wood). Everything works as normal when plugged in.
    2016 T@b 320 Max-S (Silver/Red Trim) / TV: 2019 Ford Flex
    "Growing old is mandatory. Growing up is optional."
  • Kr@ckenKr@cken Member Posts: 146
    Thanks for your reassurance.
    Kr@cken
    2020 Subaru Ascent
    Thanks for this thread!  I just plugged in at home.  Dogbone and surge suppressor lights are on, but, for the first time, the red light on the power cable did not come on.  I turned on the battery disconnect switch and the monitor instantly jumped up from 12.6 to over 13, so I assume all is well.  **gulp**  :#
  • pthomas745pthomas745 Administrator, Moderator Posts: 4,281
    Whenever you plug a power cable in, or connect a solar panel to the battery, the little monitor inside the trailer will jump into the "13V" range to indicate charging is taking place.  So, yes, your charging is working.
  • fmcnuttfmcnutt Member Posts: 3
    Call me AR but, not too often: butt, I would like to replace that red light. I find it handy for what I believe is the very reason it is there - to confirm power is at the plug, at the plug. Savvy?
  • MuttonChopsMuttonChops Member Posts: 1,843
    fmcnutt said:
    Call me AR but, not too often: butt, I would like to replace that red light. . . .
    LOL,   :p:)
    Those RV-30Amp-Power-Cables tend to have molded rubber(?) housings.
    Your best options are to:
    1 ] - - Ignore the dead LED
    2 ] - - Find a different "power on" indicator for your "" AR ""
