Tire Covers
Hello!  Just bought my 2014 TAB and will be storing it outside for the next couple of months.  I want to purchase Tire Covers and would love a suggestion on what size and brand my fellow TAB owners suggest?
  • EWizard
    EWizard Member Posts: 106
    I too would like this information.
    2005 T@B U model
  • John_and_Kris
    John_and_Kris Member Posts: 302
    They have covers available at Camping World. You just need to get the size of your tire and match it to the appropriate wheel cover
    South Carolina
  • TABaker
    TABaker Member Posts: 432
    I bought covers for 16" tires.  First set was vinyl, and I was gifted a set of cloth covers.
  • KAR
    KAR Member Posts: 86
    Is there any reason to cover the tires? We read about it's nice and helps with UV breakdown but nothing really says it's necessary. Thoughts?
    2015 Tab S with Alde
  • webers3
    webers3 Member Posts: 450
    We don’t put tire covers on car tires, why RV tires?
  • falcon1970
    falcon1970 Member Posts: 758
    From experience I can tell you that tires sitting in the sun will dry rot.  If they are on a vehicle that is driven a lot it will take a longer but tires sitting on a trailer that is moved only a few times a year will dry rot in only a few years.  A trailer with dry rotted tires may differ a blowout going down the road.
    Walmart sells Camco vinyl tire covers.  Cheap insurance in my opinion.
  • Denny16
    Denny16 Member Posts: 5,430
    edited September 2020
    Covering the tire will help some, but the tire will still oxidize and breakdown.  Covers are good on tires that are facing South and get a lot of direct sun.
     RV Tire’s should be replaced on a time schedule, not just based mileage, as a bad tire could still have good tread, but not be serviceable.  Check the sidewall of a tire and look for small cracks or checking, if you see this issue, time to replace the tires.
    I get 4-6 years on my boat trailer tires, but they are stored out of direct sun for the most part.  When I had my Kenskill, I used plywood panels cut to fit in the sheet well to cover the exposed side wall of the tires, this worked well for a trailer that was not moved much.  You could also use a good tire dressing on the tire sidewalls, to reduce UV damage and oxidation issues, and possibly prolong tire life for the trailer Tyres.
  • Marceline
    Marceline Member Posts: 1,779
    FWIW the Classic Accessories trailer cover partially covers the tires.
    https://amzn.to/2F0DS7o
  • Denny16
    And and a small bit of plywood or plastic under the cover in front of the tire would cover the rest.
  • KAR
    Thanks all.
