Trailer rear brake lights
Hi all,
Well, the time is getting closer and closer to when we can actually take our Tab out for its maiden voyage. We've been delayed about 2 months for various logistics and parts issues but that's a story for a different time ... today we finally got our tow hitch receiver installed on our TV!
We got home and connected the 7-pin and all seemed to be working great. Tested again with the Curt Echo brake controller this time. The first shot there was some quirky behavior and only the right side would illuminate. After disconnecting and reconnecting the Curt, all seemed to be well.
However, 1 thing stood out to me and my wife - only the 2 larger red circular lights would respond to our inputs. The smaller outermost lights did not illuminate regardless of turn signal, headlight, brake application, or hazards.
I'd like to ask:
a) is that expected?
b) if so, what is the function of the 2 smaller rear red lights?
2021 Tab 320 S Boondock | 2021 Ram 1500
  • N7SHG_Ham
    N7SHG_Ham Member Posts: 1,261
    Those are reflectors ONLY. You only have two taillights
  • Denny16
    Denny16 Member Posts: 5,430
    And these two tail lights contain the turn signal and brake lights.
  • JabGopher
    JabGopher Member Posts: 63
    Thanks!
  • DINDAnLAN
    DINDAnLAN Member Posts: 75
    I had a reflector fall off of our 2020 T@b 400. I need a new one. Does anybody know if you can buy these exact ones elsewhere besides NuCamp? Also what is the proper way to mount it?
    Thanks
    Linda & Dan
    Cleveland, Ohio
    2018 Ford F150 XLT pulling a 2020 T@B 400
    LIFE IS GOOD!
    ScottG Administrator Posts: 5,691
    @DINDAnLAN, several years ago I had one almost fall off. I can't advise you on a replacement, but IIRC I reattached it with liberal use of 3M automotive trim tape. Good stuff!
  • falcon1970
    falcon1970 Member Posts: 758
    Looks to me that those reflectors are standard automotive items.  You can probably find them at any auto parts store.
