Purpleline engaged or not?
Quick question for your Purpleline owners. Do you leave yours drivers engaged when your T@B is parked? It sounds like in Europe they use it as a braking system but I have always retracted mine. Just wondering what your prefer and why?
Kr@cken
2020 T@B 320 Boondock
2020 Subaru Ascent
Bainbridge Island, Wa
    edited September 2020
    Mixed.
    Engaged in camp, always, no exceptions.
    At home, depends on how often I need to move the trailer, because with the Enduro, to engage it I need to grab the trailer keys (usually upstairs) and get the lever out of the compartment, + unlock and unchock the wheels, whereas if I leave it engaged, I just punch the code into the trailer door lock and pull out the remote, because it basically acts as a parking brake. Trailer is parked in front of the door from the carport to the house, so depending on what I’m doing there are times when I move it out of the way every few days. Right now, it’s chocked, both wheels locked, and the Purpleline retracted, because it’s unlikely I’ll need to move it for a while.
    The longer it’s engaged, the greater the risk of flat-spotting the tires, of course, but thus far I’ve left it for weeks sometimes and not had a problem.
  • cyoungcyoung Member Posts: 54
    Engaged when camping only. No need to have it on when sitting in your driveway.
    2021 320 BOONDOCK, 2017 F150 2.7 ECOBOOST
    Mine stays engaged sitting in the garage at home, but I tend to disengage it when at a campground after completely setting up because I have my BAL leveler on one wheel.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • Kr@ckenKr@cken Member Posts: 146
    Thanks! I was wondering about the flat spotting. I was also wondering if it would function as a theft deterrent. Impossible to move with the drivers engaged. I guess if they wanted the T@B bad enough they could remove the drivers but that would be quite time consuming.
    Kr@cken
    2020 Subaru Ascent
