Momentary Lapse of Reason
FinchyFinchy Member Posts: 41
edited September 2020 in Tips & Tricks
I backed into my son's car today with my T@B. Really stupid and I'm kicking myself for it. It wasn't in its normal spot and I was fresh off a nap...oh well, no excuses. I wish it would have been backing into a campsite at the very least :) Does anyone know the best way to fix and injury such as this? Pretty clean split. I don't care as much for aesthetics(a neat repair would be nice) as much as maintaining the integrity of the shell. Any advice would be much appreciated!  Thanks
(Photo resized and reoriented!)
2019 Tacoma Off Road
2014 T@B S Wet Bath Max Plus
Whenever you find yourself on the side of the majority, it is time to reform (or pause and reflect).
-Mark Twain
    I think I would get a quote from a body shop.
  • FinchyFinchy Member Posts: 41
    Probably so. Other than this, the thing is in great shape. To be honest, I don't want to spend $500 for this minimal repair. I was hoping someone had a cheaper fix option.
    -Mark Twain
  • trimtabtrimtab Member Posts: 237
    I have a 320-s, which looks different from you setup..on mine, I could unscrew the part, pull it back together with blue tape on the outside, then epoxy and fiberglass strip on the inside.  I don't know if yours comes off the trailer as easy as mine does.
  • linolino Member Posts: 232
    You could get an estimate for a replacement part and then it would look new
    @trimtab nailed it(no pun intended). Remove the part and using fiberglass cloth & epoxy resin, rebond the split, from the back. The crack can be masked with a bit of bondo from the front, finish sanded & painted(rattle can primer, and as close a math as possible in rattle can.
  • GeoGeo Member Posts: 160
    @Finchy ,  The plastic can be glued back together using PVC plumbers glue. For best results you would need to remove the trim piece for proper alignment and holding in place until the glue set. The result would be a water proof repair but would leave a visual line, showing your scar.
    Geo & Liz
    T@BMahal
    '04  #100
    This is a particularly boring story, Verna. Thanks all! I will post and update. I will probably do my camping for the rest of the year and replace the part over the winter months. We shall see.
    -Mark Twain
    @Finchy - is that the same 2014 CS-S in your signature line?  I can’t find a 2014 with round tail lights.
    It is a 2014...says so on the registration :)
    -Mark Twain
    Unless it's "I got drunk and went to Vegas and got a tattoo", or "I was stationed in the South Pacific during the war and I met....", it's still a better story. (love it @Verna!)
    Sorry about your mishap @Finchy. It hurts! BTDT
    You could do the “more proper” repair going the fiberglass route.  Or just mend it with Plasti-Mend.  I personally like JB Weld products.  They also make a plastic mend product.
    Odessa, Fl.
  • MarcelineMarceline Member Posts: 1,659
    Do you have a clamshell (CS-S as in your signature)? I can't figure out what corner that is.
  • JanandDaveJanandDave Member Posts: 119
    @Marceline
    Rotate 90 degrees counterclockwise, passenger side, non LED taillight of 320 S.
    Best I can figure.   :)
    2016 T@B 320 Max S  "T@BsentMinded"
    2009 Subaru Outback R 3.0
    2022 Ford Ranger XLT Super Cab
    @Marceline
    Thanks. That makes more sense.
    @Finchy "CS-S" (as shown in your signature) means a clamshell T@B with a wetbath. If you don't have a clamshell model you might what to correct your signature to avoid confusion.
    For now, I'd put something over it to keep any water out.
    I will change it. I am confused by the model numbers.
    -Mark Twain
    Now I see what area that is.... CS-S confused me.
    It seems like removing that body panel could be a major undertaking, not sure. Screws and sticky sealing goop at a minimum.
    If you haven't already figured it out,  you can get at the back side of that plastic from the inside. You need to remove the back shelf and open up the insulation that's back there. A PITA either way.
    Maybe simply secure the crack from the inside, with fiberglass and epoxy, and bondo it on the outside and paint it? Maybe incorporate your new lightning-bolt graphics?
    Thanks, ChanW. I'm taking it to an RV body shop. They will make it look brand new. NuCAmp only has white in that particular part, anyway. I am debating just sealing it with Plasti-mend and painting it with some T@B touch up paint I have. The body shop repair, while looking minor will take some time to do correctly and probably run me $500.
    -Mark Twain
    Yeah. I'd go with plasti-mend and fiberglass fabric.
    $500 seems like a reasonable price for a shop to do it.
    How about a nice American flag sticker?
    1. Hash  T@B Fun
