 susaninnh
                    Member Posts: 11
susaninnh
                    Member Posts: 11
            I’ve seen postings about repairs for sagging roofs and soft floors in Thor/Dutchmen t@bs, but what about a soft wall? The wall under the round window on the drivers’ side of our 2004 t@b is very soft. What is the repair for that? Is there way to replace a section of the wall?
T@BMahal
'04 #100
Once it is dried out, the panel should be less soft. Then add the epoxy wood treatment, reseal the edges around the window opening and reinstall the window.
Check carefully all around the bottom seam of the wheel wells as that is the most common area of water and dust intrusion for DM T@B's
This is our removed damaged floor - the area by the door was the worst.
Check top side and bottom side for softness. DM T@B's are constructed with Luann plywood that does not have water proof glue used for assembly and is not water or rot resistant.
T@BMahal
'04 #100
Lluann ply is a relative soft wood, originally from the Philippine Islands, and is prone to water damage and easily rots when left at the right moisture level.
T@BMahal
'04 #100
