This mod is an inexpensive alternative to installing a whole new fan: https://tab-rv.vanillacommunity.com/discussion/comment/140981/#Comment_140981CharlieRN said:The precise fan model is not listed on the invoice for my Boondock, but I believe it’s the Fantastic 1250. I could not find any information on its power consumption on Dometic’s website or in the pdf of the owner’s manual there. Based on what Jenn G posted, however, the fan draws 1.2 to 2.75 Ah depending on mode and speed. That’s a fair amount of power for a device that will likely need to be used quite a bit. I understand that installing upgrade kit will provide more speed controls and lower power usage but at a considerable cost.
TerryHutchinson said:If the published numbers are anywhere near accurate, either model consumes far less power than the OP originally suggested
Snohomish WA, 2024 3.6L Grand Cherokee
managed by VE Smart Network
Thanks again to all the T@B owners who populated this thread with so many helpful comments and suggestions. Special thanks to DougH and BrianZ for keeping me on the straight and narrow WRT to terminology. Here's an outline of my tentative plans, based largely on this thread's informative feedback:
Battery - upgrade stock 12v to a pair of 6v, 200 - 225 Ah batteries. For this initial outfitting, the plan is to use less expensive flooded cell batteries as suggested by elbereth. I think the battery change will also require an upgrade to a 15 amp solar controller. A sure addition is a [wireless] battery monitor.
Fan - take delivery with the standard Dometic 1250 and upgrade it with an aftermarket PWM controller as suggested by among others, Sharon_is_SAM and Terry H. Also add the Camco vent hood per recommendation by Marceline.
Possible later addition: Supplementary power - option 1 is a portable solar system such as the Renogy or Jakery; option 2 is a small propane generator and second storage tank.
Sharon_is_SAM said:@CharlieRN - when you say wireless battery monitor, do you mean one that you access via a phone?
ScottG said:@CharlieRN, I think the size of your solar controller is driven by the maximum output of your panels, so you may not need to upgrade the controller unless and until you add more panel capacity. (Which is something you might need to do to charge those big batteries up quickly.)
I think in this case either would be technically correct. However--since amp-hours are really more about battery capacity--I would also have been inclined to just say "amps" when referring to how much current a device draws.Sharon_is_SAM said:...(Did I get it right... amp hrs? You know I wanted to say amps!)
