2014 T@B part issue
FinchyFinchy Member Posts: 41
I contacted NuCamp and they have a part I need in white only. Although it could be painted, I would like the original yellow. NuCamp will not give me a ballpark price of the part, but are referring me to go through a dealer. I realize this is the policy, but the dealers in CO are either far from me or very poorly rated. Does anyone know, if there is a good dealer in the US that might have this part on hand and be able to give me a price. OR is there another place to look for older T@B parts. I'm attempting to find the best(and cheapest) way to fix some minimal damage to the rear. Thanks!
Rear shroud – part id 78-75-6783.
2019 Tacoma Off Road
2014 T@B S Wet Bath Max Plus
Whenever you find yourself on the side of the majority, it is time to reform (or pause and reflect).
-Mark Twain
    If I recall, the replacement plastic trim parts for older Tabs are only available in white now, so any new trim will require painting. You might check for RV salvage yards; they won’t be able to ID by part, but may be able to search their inventory for the correct piece if you send them a photo. And if the piece is small enough, they may be willing to ship.
    Otherwise, for ordering from nüCamp, Missouri Teardrops is often recommended as a good place to deal with for nüCamp orders. A good car paint place should be able to match the yellow.
