Any one know the Amps rating for 120 VAC receptacle on top of the T@B 320's sink? I want to put a standard Kcup Coffee machine there and wonder what is the rating of this 120VAC's receptacle?
+1 what MuttonChops said. The amperage of a receptacle is limited by the breaker or fuse protecting its circuit (which in turn depends on the gauge of the wire in that circuit). In this case that circuit is limited to 15A.
Keep in mind that with multiple receptacles on one circuit, if you are running something else in another location, you may not have the full 15A to work with. Regardless, the worst that will happen is you will trip the breaker.
2015 T@B Max S (320) 2015 Nissan Frontier SV V6 4x4
the WFCO Power Center.
Recommend you check-out the Users manuals & Resources section of this forum. [ link on left side of forum page]
Odessa, Fl.
And we've used a Ninja Foodi grill on the outside outlet. It's 1760 watts and 12 amps with no problems.
Tampa FL
