Refrigerator not work-in on AC power.
angelo23
Member Posts: 1
I have a 2016 320S with a Norcold refrigerator. Only works on Propane and Battery. When checking the outlet located underneath the sink there is no power.
The circuit breaker has not tripped and all fuses are fine; however, the refrigerator does not work on AC power. Does anyone has any advise. Please advise.
If the fridge is on the galley circuit, try checking the GFI outlet in the galley area, to make sure it has not tripped.Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0
The fridge is on it’s own 20 amp circuit. Reset it by turning it off then back on.
- Hash T@B Fun
2 -
Assuming your other AC circuits are working properly (and the reset suggested by Dalehelman didn't work), I'd start looking for a loose connection in the fridge circuit. Could be in the outlet, at the breaker, or at the neutral/ground bus. Could also be a bad breaker. Not many other places where a dedicated AC circuit can fail...
2015 Nissan Frontier SV V6 4x40
- 417 Service/Maintenance & Recall Notices
