When do YOU stop T@bbing?
KB_TAB_T2
Member Posts: 31
I want to camp/hike all through the winter here in Virginia but my wife says November/December is cut off until March-ish.
I figure we have heat/furnace access to electric in most or all state parks and plenty of campsites to choose from.
Thoughts?
This is our first year with a camper.
Thoughts?
Kristen and Bryan
2022 Nissan Frontier 4D 4x4. 2005 T@b T2
Powhatan, Virginia (Just west of Richmond)
2 Canine traveling companions - Luke and Solomon
Your black tank and gray tank need to be protected from freezing. That requires modification.2021 Tab 400 Boondock
2020 Audi SQ51 -
Fortunately/unfortunately we dont have either.dlb said:Your black tank and gray tank need to be protected from freezing. That requires modification.
Kristen and Bryan
2 Canine traveling companions - Luke and Solomon0 -
You can winterize and still camp, just no running water. Lots of owners do. Well..some. Threads here about camping after winterizing.
If you can find open campgrounds, with open toilets, you're fine in your Tab. We've camped at -5°F below zero, and were able to keep it cozy. Took a while to get it warmed up though.
Which Tab are you talking about?
You can count on the comfy bed, the Alde for heat, the stove for a quick coffee (I'm sure you'll do all your cooking on the campfire
Add a side tent for room for gear - coats, boots, skis etc. Nice to have the extra room.
You can't count on water or plumbing. You can use the toilet with a bag, with kitty litter, or, better yet, the campground facilities.Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
The OP has a Dutchman TaB T2, it does not have a head, black tank or gray tank. Water tank is a 5 gal jug with a hose under the sink counter. Heat is a Atwood 200,000 BTU LP furnace with thermostat, no Alde, no hot water. So he should stay toasty warm. There is nothing to Winterize. This was a camping trailer at its basic level, simple and functional.
cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.2 -
We have a 2005 T2ChanW said:If you can find open campgrounds, with open toilets, you're fine in your Tab. We've camped at -5°F below zero, and were able to keep it cozy. Took a while to get it warmed up though.
We would mostly only camp state parks and campgrounds for now. Until we camp with the T2 a bit more and make sure there arent any issues we missed.Kristen and Bryan
Many state campgrounds do close for the winter. Be sure to check ahead of time. Other states parks keep one restroom open along with limited campsites open for the winter, along with limited availability of weatherproof water spigots.Verna, Columbus, IN
Never. I winterize, and keep on camping.2015 T@b S Max white with silver trim. 2018 GC Trailhawk.1
We will camp across the winter if it’s not consistently below freezing. Here in Tennessee, the state park CGs are open, and some of the Federal CGs have some sections open. I’m not sure what this Covid Winter will look like, but usually the CGs are empty in the winter. It just means I may have to winterize/dewinterize several times. We love winter camping!2
For those of you with a cassette toilet, how do you “flush” after using it, without having water in your fresh water tank? Put another way, how does one winter camp with a cassette toilet after winterizing?Jim and Robin / 2021 320S / 2015 Jeep Cherokee Trailhawk / Oregon0
Assuming the cassette doesn’t freeze: (big assumption, we don’t know yet how well insulated that space is on a Tab) Use bottled water kept in a warm part of the rig.jimrj said:For those of you with a cassette toilet, how do you “flush” after using it, without having water in your fresh water tank? Put another way, how does one winter camp with a cassette toilet after winterizing?
Assuming the cassette area may freeze: Flush with pink RV antifreeze (literally, do your business and wash down with approximately equal amount antifreeze)
With the above two options, you’re assuming you have a place to dump, which in winter is not guaranteed. Many dump stations close over winter, as do some campground bathrooms.
Alternatively, line the toilet with a double layer of bags, + a scoop or two of kitty litter, pine pellets, or poo powder (superabsorbent polymer that gels on contact with liquid). Tie off bags and dump in trash after a few uses, replace.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW1 -
just make sure you take any extra water inside your "toasty" trailer...luckily our water in the car didn't freeze but it was an oops for the coffee maker water..last January in Texas with our T@G!Former 2017 T@G Max XL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada0 -
Given I've camped in all seasons in a tent or a van, I see no reason to stop that with my T@B. Just carry bottled water once the trailer has been winterized and there are multiple options for managing toilet needs without involving the built-in plumbing. I think if you want to go, you will find a way to make it work! However, towing a trailer in snow and ice might be a deal breaker for me.
2018 T@B 320 S Boondock | 2015.5 Volvo XC60 T6 AWD | Seattle, WA, USA
"Blessed are the curious, for they shall have adventures.”― Lovelle Drachman1 -
For me, it’s not just the snow and ice, it’s the set up and tear down in the cold rain we get in the NW all year round. I freely admit I’m a fair weather camper; as long as it remains dry, I’ll enjoy it. Once water starts falling from the sky in any form, meh, I’d mostly rather be at home. I can be persuaded out for a group camping event regardless of weather, but if it’s just me, no thanks.PNWtabber said:Given I've camped in all seasons in a tent or a van, I see no reason to stop that with my T@B. Just carry bottled water once the trailer has been winterized and there are multiple options for managing toilet needs without involving the built-in plumbing. I think if you want to go, you will find a way to make it work! However, towing a trailer in snow and ice might be a deal breaker for me.
For @KB_TAB_T2, something to consider is finding out *why* your wife has a cutoff date in mind. If she just thinks the trailer isn’t capable, it is, with some adaptation around the plumbing. But if she’s like me and doesn’t enjoy being outside in cold or wet weather, you may be better off with a different vacation alternative for the winter months. Making her go along on the kind of trip she won’t enjoy (and may actively hate) is not going to be a good idea. You might need to figure out a compromise. These trailers are TINY, being cooped up in one for days on end in stormy weather is not my idea of fun.
Pacific NW2 -
Four VA state parks with full service campgrounds are open year-round..
https://www.dcr.virginia.gov/state-parks/winter-camping
..plus a handful offer primitive camping, but not sure if those would be accessible for a trailer.
RV: 2018 T@B 320S, >100 mods2 -
Thanks Brian I did see that and hope to take advantage of them this winter.BrianZ said:Four VA state parks with full service campgrounds are open year-round..
You ever winter camp?Kristen and Bryan
@KB_TAB_T2, no, we never have, though have been camping in freezing temps for a few hours in NC mountains in late Oct & might see the same again this year. We generally shut down & winterize in mid-Nov until April.
Under "Camping Details" on this page, it specifically mentions only James River State Park as having drive-in primitive camping available..
https://www.dcr.virginia.gov/state-parks/camping
..and others with hike-in or canoe-in primitive sites.
Here is a list of state parks with RV camping..
https://www.dcr.virginia.gov/state-parks/recreational-vehicles
We've camped at all except two of these, which we will get to next week, plus one more that is not on the list - Breaks Interstate Park on the border with KY. It is a partly state funded park, but jointly owned & managed with the state of KY, one of only two such interstate parks in the country. So, after our next trip, we will have camped at all of Virginia's state parks that offer camping with our T@B, in just over 3 years.
RV: 2018 T@B 320S, >100 mods1 -
Nice!BrianZ said:@KB_TAB_T2, no, we never have, though have been camping in freezing temps for a few hours in NC mountains in late Oct & might see the same again this year. We generally shut down & winterize in mid-Nov until April.
Our plan is to do the same with the state parks, with others thrown in.
We are booked in at Holliday lake for Halloween and fairy stone for Thanksgiving.
We are looking forward to many new outdoor experiences and meeting new people.
Thanks for the infoKristen and Bryan
I liked @ChanW comment on putting coats / boots outside with a side tent. This will be our first winter w/ the t@b but we've struggled w/ the coat/boot issue. We have an awning that we could use but how to hang the coats? Anybody have a source or work around for using the outside table extrusion to hold a pole for a coat rack?
As to toilet as suggested we'll use antifreeze and find a place to store the water, probably a jerry can in the bath sink as we don't really use it except to store the toiletries. I've toyed w/ the idea to temporarily remove the sink pipe and put a catch basin there as it'll use the built in sink to wash up. We've only experienced 40 F temps so far but been very impressed with the Alde's quiet heating ability.Snohomish WA, 2024 3.6L Grand Cherokee
managed by VE Smart Network0 -
@MarkAl - we have some cheap, plastic suction hooks for light weight jackets, towels and raincoats that we stick to the passenger side of the TaB inside the tent. There are some heavier suction hooks for winter gear that would work as well. We use a double hook on our TaB bathroom mirror that holds up to just about anything.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
We plan to put wet boots and rain gear in the washroom, on a pole held between the towel hooks, (installed one by the shower head) to let them dry.
I love nice weather but I prefer camping in the off season and winter. Small to no crowds depending on season. When there is snow, it's just a whole different beauty and perspective of nature. I've camped in minus 7 f and the tab is always able to deliver toasty warmth. I like to ski and snowboard but haven't been in the last couple of years. I plan to go this winter with the tab in tow, I'm 61.2
@MarkAl, we're with @Sharon_is_SAM. Suction hooks. Ours are strong enough to hold our coats. We stick them on the plastic trim around the windows.
I like @Denny16's idea about the use of the washroom.Chan - near Buffalo NY
I must be using the wrong type of suction cups. My experience is unreliable.
I have a couple of heavy duty Command Hooks on the outside of the trailer by the door. Great for jackets, raingear. They haven't moved in 13 yearsCarol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL0 -
I'll see if I can find what we have for you.
Edit:
This is what we use. Looks like it's out of stock and will take some searching.
https://www.amazon.com/gp/product/B0079LWUU6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The little lever increases the suction.
These have had mixed reviews - but mine haven't had the problems that others have.MarkAl said:I must be using the wrong type of suction cups. My experience is unreliable.
