USB phone Charger
My 2 USB phone charger at the bed for 2017 T@B320S have "NO POWER".  However, the cigarettes next to USB charger has Power. My battery is good, I am also on shore power. I checked fuses box, nothing open up. Anyone knows this issue?
Thanks for all comments.
    edited October 2020
    The USB outlets have been known to fail.  Either replace it or change it out for a robust 12v outlet and use a USB adapter.  FYI:  The USB outlets draw phantom power.
  • huanvanho
    huanvanho Member Posts: 48
    Thanks Sharon. Yes, it failed. I have used Cigarette USB adaptor in the mean time. It would be nice if to know where is the problem? Is it the plug that I need to change out? where can I buy the part?
  • huanvanho
    Do you have wiring schematic of the 2 USB plug? What is phantom power? I want to trace to see if I have power right at the USB.
    pthomas745 Administrator, Moderator Posts: 4,703
    "Phantom" power is the various drain of the battery that can't be shut off.  Like the gas monitor, and the TV/Radios.  The only way to stop these things from using power is to shut off the battery entirely with the battery switch, pulling the battery fuse, etc.
    Here is a thread that discusses the replacement of the USB "power centers."  It seems to be an easy process. Pictures included.
  • 4ncar
    4ncar Member Posts: 1,072
    @huanvanho the USB jacks have no real serviceable parts to them. You best bet is to google search(or amazon) USB  faceplates, I am sure many options will pop up.
  • Verna
    Verna Member Posts: 6,876
    The OP (Original Poster) has a 2017 T@B320S, as stated in the first line of his post.
