USB phone Charger
huanvanho
Member Posts: 48
My 2 USB phone charger at the bed for 2017 T@B320S have "NO POWER". However, the cigarettes next to USB charger has Power. My battery is good, I am also on shore power. I checked fuses box, nothing open up. Anyone knows this issue?
Thanks for all comments.
The USB outlets have been known to fail. Either replace it or change it out for a robust 12v outlet and use a USB adapter. FYI: The USB outlets draw phantom power.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Thanks Sharon. Yes, it failed. I have used Cigarette USB adaptor in the mean time. It would be nice if to know where is the problem? Is it the plug that I need to change out? where can I buy the part?
Do you have wiring schematic of the 2 USB plug? What is phantom power? I want to trace to see if I have power right at the USB.
"Phantom" power is the various drain of the battery that can't be shut off. Like the gas monitor, and the TV/Radios. The only way to stop these things from using power is to shut off the battery entirely with the battery switch, pulling the battery fuse, etc.Here is a thread that discusses the replacement of the USB "power centers." It seems to be an easy process. Pictures included.
Towed by 2014 Touareg TDi -
@huanvanho the USB jacks have no real serviceable parts to them. You best bet is to google search(or amazon) USB faceplates, I am sure many options will pop up.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
The OP (Original Poster) has a 2017 T@B320S, as stated in the first line of his post.Verna, Columbus, IN
- 917 Introductions
- 73 Teardrop Groups & Links
