T@B400 sink plumbing photo
I removed the bathroom sink from my T@B400. I have never used it. I heard the drain doesn't work well. I'd rather use the space for more room in the shower and for a storage shelf. I have not figured out the new shelf yet but want to share a photo of the sink plumbing for those that haven't seen behind the sink.
2019 T@B400
Southern California
Full-timer since 2019
    DenisPDenisP Member Posts: 542
    @jimcenname If you remove the outside shower, the rest of the sink drain plumbing is revealed including a p-trap.  Probably the best location to plug the drain if you are abandoning the sink.
    2013 Tundra TRD 5.7L
    Massachusetts
    edited October 2020
    My TaB 400 had the sink omitted, and the factory covered this plumbing access area with a fiberglass panel, similar to what you would find in a home shower enclosure.  I like the extra space having the sink removed.  Now thst I know where the plywood behind this panel is, I plan to just add a towel hook and a wee shelf.
    HoriganHorigan Member Posts: 617
    Here's what we did with that space.
    Rich
    2019 T@b 400
    Bellingham WA
    jimcennamejimcenname Member Posts: 271
    @Horigan: Thanks for sharing your shelf idea. Looks like that might be 3/8" plywood. I am trying to manage the weight I add to the T@B. The sink assembly I removed weighed about 10 pounds.
    2019 T@B400
    Southern California
