T@B Converter Fan.... Does it run every time it's charging the camper battery, or only when it needs cooling while charging the camper battery? (I added some circuits to my converter, and have had it off and apart for several days). I got everything connected again, and everything works, but I have yet to hear the converter fan. I am currently running lights and the 12V fridge with the trailer unplugged, and I'll give it a couple of hours. WFCO 8725P
Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
0 ·
WFCO CONVERTER FAN NOTES: While the fan on the WFCO cools the 12V circuit board, it is load based, not temperature based. Therefore, the fan will turn on, and remain running, as long as the converter is drawing a certain 12V load threshold. They don't say what the load threshold is. Thus, the fan will likely kick on, and remain on, whenever you are running a sufficient load (e.g., the water pump, turning on lights, the radio, etc.) If the power draw (i.e., load) drops below the pre-determined threshold, the fan will turn off. NOTE: Even without a load, when you first plug in the trailer 120 VAC power, the fan will briefly turn on, then off (due to charging of the circuit board capacitors.)
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
MOUSE-KE-T@B
Harvest, AL
Believe the Power Center Fan will only operate above a specific 12VDC Load (current draw) when the Power Center Convertor {120VAC -to- 12VDC} circuit is operating.
The Power Center Fan will not turn-on if T@B Battery Only 12VDC is being used . . . the convertor circuit is off so no power center internal heat is being generated.
MOUSE-KE-T@B
Harvest, AL
Otherwise I rarely hear the fan run.
MOUSE-KE-T@B
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
P.S. I just found this info on the "load" issue (from WFCO web site FAQ):
Should my fan run all the time?
No. The fan is controlled by the load. The fan will start running at a low speed when you have approx. 3.0 to 6.0 DC Amp draw. It will increase in speed as you add more load until you have approx. 14.0 to 15.0 Amps draw. At this point, the fan is at its maximum speed and will stay there even if you add more load, should amperage drop below 3.0 to 6.0 DC amps, the fan will shut off.
ALSO, for additional info on the fan operation, watch this WFCO video:
Why does the fan on my converter run all the time?
"Test the thermostat/temperature sensor unit which controls the fan by blowing heat onto the heat sink using a hair dryer or a shrink-wrap gun. Use your test meter to confirm 120-volt power is passing to the thermostat/temperature sensor unit, and then that 120-volt power is passing from it after it heats up. If it is not, the thermostat/temperature sensor unit is faulty. With the 120-volt power on, if the thermostat/temperature sensor unit is functioning and power is conveyed to the fan but it does not start up, the fan is faulty."
MOUSE-KE-T@B
Harvest, AL
