Identifying My Boondock for Correct T@B 320 Cover
DigPolo
DigPolo Member Posts: 52
edited November 2021 in Products and Accessories
Time for a trailer cover, but need help identifying my 2018 320S Boondock. How do I figure out what version of the Boondock I own? Outback Boondock, Boondock Lite and Boondock Edge are my options when selecting which cover I need.
We bought her from a trailer dealership, but they did not have any info on the T@B.
2018 T@B 320 S Boondock - 2011 Toyota Tacoma - Huntington Beach, Ca
  • VictoriaP
    VictoriaP Member Posts: 1,496
    They’re all the same dimensions, at least through 2020 (not sure about 2021). The Outback is the same model as your 2018 Boondock. For 2019 (and 2020, I think), they split the model into Lite and Edge versions. The Lite lacks the rear rack, full size spare, and the grey Marmoleum flooring of yours, the Edge added a front light bar and rear spotlights.
    Regardless, the same cover will fit any of them.
  • DigPolo
    @VictoriaP THANK YOU! Great info
  • Parlando
    Parlando Member Posts: 165
    I called NuCamp and asked if there was any problem with using a Costco tarp. They said absolutely none. Costco tarps are cheap and heavy weight. We tie a 3' piece of rope to each corner and then my wife and I "sail" it over the back, over the rack, over the roof vent and all the way to the front. Tie it down and we're good.  Cheap, sturdy, easy.
  • DigPolo
    @Parlando Hmmmmm, intriguing idea.
  • BDA123
    BDA123 Member Posts: 22
    I do the same on my TAB 400. Costco tarp brown side down. Leaves plenty of ventilation, fits from handles to handles, and for a two pack for $20 you can replace them annually. I park mine on the side of a house under trees and it is essentially for keeping leaves off the top.
    Trailer - 2018 Tab 400 with Solar
    TV - 2014 Toyota Tacoma Double Cab with bed rack/truck tent
    Adds - Jackit bike rack with tongue rectangular tool box
