Water pump and fresh water drain
System
System Administrator Posts: 192
This discussion was created from comments split from: Hot water, fresh water.
  • Leb
    Leb Member Posts: 22
    Hi All,
    A newbie question for a T@b 320 S 2018:  Does anyone have pictures and/or diagrams pointing out the fresh water valve and which switches to turn (and in which direction) to empty the fresh water tank? Also, the water pump whirls but not a drop of water drips out of any where?  What might be the problem, along with fixing the trouble?  Help is truly appreciated!
    pthomas745 Administrator, Moderator Posts: 4,685
    edited October 2020
    Welcome to the Forums.    The fresh water tank drain is just forward of the front step.  Is anything coming from your water lines?  Air?  How full is your fresh water tank?
    (PS:  you might want to start a whole new thread for  your pump.....you will get a lot of help on a new thread.)
    Here is a thread about the fresh water drain that has a picture of what to look for.
    @Leb - just to confirm, you don’t mean the Alde hot water tank - just the fresh water tank?
    Regarding the pump:  did it work before?  Is the fresh water tank full?  Did you tighten the plastic filter housing and pump hoses?
