This is the second year I have winterized via the compressor blowout method on our 2018 320S. The t@b was connected to 110AC so I could use the interior lights. The compressor was plugged into a garage outlet, and pressure was kept below 50.
Everything went fine (I was foolishly feeling a bit cocky, Oh yeah, I’ve got this!). But then, the final winterizing task I did (and for the first time) was to disconnect lines to the water pump, wrap it in a towel, and turn the pump on/off a few times to help it drain. A few tablespoons of water was released and I reconnected the hoses. Immediately following…the power started rapidly turning on and off, then off.
I fussed several times with the exterior connection and got flickering power for a few seconds, then none. I flipped the converter breakers on/off but no power was on when I did that so I don’t know if it accomplished anything - and checked the garage connection, which was fine. Still no power.
Could I have accidentally disconnected something while emptying the water pump? It’s very hard to see back there.
For both 110 and 30amp, the exterior connection has always been a bear to wrestle into compliance. Never easy. Could it be broken? Can it be repaired or replaced, maybe with an easier to use connector?
~ As always, thanks to the Forum knowledge sharers.
The sizzling, crackling sound came from where the 15/30 pigtail plugs into the t@b, but I don't know which end made the sound - pigtail or connector. I plugged it in again. Now all is quiet, with no flickering or power (except 12V when the battery is turned on).
The house outlet that the functioning heavy-duty extension
cord was plugged into works fine, and I tried a different outlet and different cord - still no power. I use a surge protector at campsites, but haven't been when plugged into the house.
Could you please tell me how to check the Tab connector? The three screws on the exterior rim were just a tad loose, and the ones under the flap were firmly tight. Or do you mean remove the connector to check screws and wires?
Also, where is, and how do I check, the ground fault connector? For Star Trek fans: “Jim, I’m a nurse not an electrician!”
With genuine appreciation, I won't mind being told its time to call in the professionals. On the other hand, I love learning new skills, and every step in the Tab learning curve is worthwhile.
https://m.youtube.com/watch?v=cP0jLKtOnYI
I forgot about this experience.
I guess between the soap and some forceful pushing it can be done. Probably get one spot started then work around the entire lip.ChanW said:@Tampakayaker, thank you! I've been looking for that!
I struggled with the dang threads yesterday for 5 minutes - It seems no matter how much practice I get, it never gets easier. Sometimes it's a breeze, and other times it's a foreign language.
Only thing is, I can't see how one would remove and replace the ring. Dish soap, huh? We'll see.
Your problem is behind the 30A female plug on the trailer. If that has felt funny plugging in and you smell smoke or a metallic odor there you no doubt have a bad female assembly or basically a bad electrical connection (loose) on the backside. If the wire harness behind that area has one wire nut that is loose the wire will heat up when any load is placed on it and over time this heating and cooling and trying to make a good connection will create a bad connection and the electrical arcing (from trying time maintain a connection or path for voltage to flow) will melt the copper conductor and it will fail. You can probably salvage the assembly. Remove the screws, pull it out and if the screws aren’t welded to the assembly use a wire brush to clean up the surface, clean the wire ends up and screw them tight to the back of the female plug end. Otherwise you should be able to replace it via a local RV supply store. Use some silicone between the assembly and trailer wall when you reinstall it and use a wet or dampened paper towel to clean up the silicone on the trailer wall before it dries.Campwise said:I agree that the outlet requires careful connecting. We do twist right then tighten the collar, and reverse when removing. But it has felt loose every time, even with careful collar tightening. Plugging in has always caused a gravity/weight pull down that feels like a slight disconnect, but this is the first time there's been a problem. Thank you for the Amazon links (the adapter isn't available in or near our rural town). I followed directions on the YouTube video for checking continuity, but couldn't get multimeter readings on any plugs... The 30amp female end does smell a little smokey, so maybe it arc'd and burned out. Fingers crossed that replacing the adapter will fix the problem! And thank you to everyone.
