I live in the PNW. A bit wet but mostly light rain and rare small hail. I am at sea level so it seldom snows. I am a bit confused about the benefit of covering the T@B if the weather is moderate.  If covering is a necessary option for protection than I am willing to do so just don’t know how essential it is. I have a cover that has a door zipper so  I could use it but I would lose that toasty warm feeling I get on the days that are sunny. Will using a cover be of any long term benefit with regards to maintaining my exterior or is ok to skip it?
                Kr@cken
2020 T@B 320 Boondock
2020 Subaru Ascent
Bainbridge Island, Wa
0 ·
A cover doesn’t protect from hail, and snow will still have to be cleared off if it’s heavy.
One reason to protect the TAB from the sun/UV.
Another to protect it from dirt, birds, etc.
The cover allowed me to crack the windows open to the first/security opening and kept the rain out. I used a generic damp rid inside to suck up the moisture (went thru 2). And being in FL, we had heavy rains most of the summer.
A cover definitely cuts down on dirt. We took the cover off, It had been on from February until last week. There was some mildew on the inside of cover and some on the TAB. The mildew on the TAB washed right off. I soaked the cover in the tub and the water turned black, so it did keep the camper clean.
Tampa FL
2020 Subaru Ascent
Q: The cover appears to have some mildew on it. Any suggestions for how to clean the cover?
A: Mildew can be cleaned off if it hasn't been there too long. Use warm water and a little dish soap with a soft sponge. Don't use anything else. If it has set into the fabric too much it's irreversible and there's nothing you can do about it. It will eventually deteriorate the fabric and it'll start to crumble or tear very easily.
Q: Since I live in a rainy climate (hello, Seattle), is mildew just a problem I will have to live with?
A: Anywhere there's water, mildew is just a problem we all have to deal with.
Q: Should the cover be used in wet conditions? Can the cover be put on a wet trailer or should the trailer and cover be dry when the cover is put on? Note, my trailer is currently stored in the open, not in a garage.
A: These Covers are meant to be used in the rain. It's an outdoor item that's it's sole purpose. The material is made to breathe a little, as to minimize mildew. But I'd make sure the trailer is dry before putting in on, yes.
Q: Any tips for putting the cover on the trailer?
A: There's no real tips. Just put it on. It's much easier to do with two people.
Q: Do you sell storage bags for the covers?
A: We do not currently make storage bags.
Q: How do I care for the cover? Cleaning, storage, etc.
A: Keep it dry when not in use.
2020 Subaru Ascent
T@B Cover Comments October 26, 2020
Interesting comments so far! Our T@B has wintered both in Minnesota and Alaska where we now live. Both locations get lots of snow and long winters. We are also subject to frequent windstorms here coming down our glacial Matanuska River valley that bring glacial dust with them that tends to coat everything. It’s snowing now in Palmer, AK as I type this.
As an RV “newbie” lacking experience I opted to get by with as little an investment as possible and bought a Classic Accessories PolyPRO3 cover back in 2015 when we purchased the T@B and were still in Southern Minnesota. Since I wanted to get one to fit over the entire camper, including the spare tire that I had mounted on the front behind the jack, I ordered one for the R-Pod that would fit up to a 17 foot trailer. The picture below taken in Minnesota shows how this works. The zippered door is a little displaced to the front, but really doesn’t interfere much with access. I also use old rags and towels with bungy cords to cushion some sharp edges on the hitch and step to reduce wear on the cover.
Now that we live in South Central Alaska and I am dealing with back problems in my 80’s, I have developed a method of installing it similar to that described by “tombeaux” using a short stepladder on one side and a taller one on the other. One difference is that when I take it off, I reverse the process to roll up each side while it still is on the camper, pull it off and then roll it up with the yellow “front” tag showing when done. Then in the spring I take the whole bundle up to the roof and unroll it from there. I still make a number of side-to-side trips on each ladder to do this, but at my age I’m in no hurry and I don’t need another person to help!
We are going into our sixth winter and the cover has held up pretty well, although I have seen some wear spots which were created by wind buffeting. So far, no noticeable mold. I seal the trailer up pretty well, cover the exterior A/C opening and use a bucket of dehumidifier compound as others have mentioned. I probably will have to replace the cover in another year or two, but in terms of the “bang for the buck” I have been very satisfied.
Hope this helps other “newbies”!
Fergie
https://tab-rv.vanillacommunity.com/discussion/comment/56950#Comment_56950
Fergie
