This is the second year I have winterized via the compressor blowout method on our 2018 320S. The t@b was connected to 110AC so I could use the interior lights. The compressor was plugged into a garage outlet, and pressure was kept below 50.
Everything went fine (I was foolishly feeling a bit cocky, Oh yeah, I’ve got this!). But then, the final winterizing task I did (and for the first time) was to disconnect lines to the water pump, wrap it in a towel, and turn the pump on/off a few times to help it drain. A few tablespoons of water was released and I reconnected the hoses. Immediately following…the power started rapidly turning on and off, then off.
I fussed several times with the exterior connection and got flickering power for a few seconds, then none. I flipped the converter breakers on/off but no power was on when I did that so I don’t know if it accomplished anything - and checked the garage connection, which was fine. Still no power.
Could I have accidentally disconnected something while emptying the water pump? It’s very hard to see back there.
For both 110 and 30amp, the exterior connection has always been a bear to wrestle into compliance. Never easy. Could it be broken? Can it be repaired or replaced, maybe with an easier to use connector?
~ As always, thanks to the Forum knowledge sharers.
Also, the interior lights don't require 110V, because they run on 12V from the battery. If it's the lights that were flickering, it was your 12V system causing it.
So it's not clear what you're saying.
#1, Is your battery fully charged?
Was the compressor and TaB plugged into the same garage circuit?
If the buzzing is at one of these places, I'd check the screw terminals inside the house receptacle or the Tab connector to be sure the screws/wire isn't loose inside there.
Or, if the buzzing is coming from the converter inside the Tab, turn off the power to the Tab, and turn off the battery switch, and check the connections on the back of the converter (inside the bench).
Let us know what you find out. We always prefer a happy ending!
The sizzling, crackling sound came from where the 15/30 pigtail plugs into the t@b, but I don't know which end made the sound - pigtail or connector. I plugged it in again. Now all is quiet, with no flickering or power (except 12V when the battery is turned on).
The house outlet that the functioning heavy-duty extension cord was plugged into works fine, and I tried a different outlet and different cord - still no power. I use a surge protector at campsites, but haven't been when plugged into the house.
Could you please tell me how to check the Tab connector? The three screws on the exterior rim were just a tad loose, and the ones under the flap were firmly tight. Or do you mean remove the connector to check screws and wires?
Also, where is, and how do I check, the ground fault connector? For Star Trek fans: “Jim, I’m a nurse not an electrician!”
With genuine appreciation, I won't mind being told its time to call in the professionals. On the other hand, I love learning new skills, and every step in the Tab learning curve is worthwhile.
You may already know this, but just in case . . . . . . . . . when attaching the 30A twist-lock plug to the trailer outlet, you initially will have the yellow connector on the cord turned slightly to the left as you push it in to make the electrical connection. Once connected, turn the yellow connector to the right to lock in the connection. Although you don't necessarily have to do it, you should also screw the threaded ring (locking adapter ring) onto the threads at the outlet. That often takes a bit of practice, and you want to be careful not to cross-thread it, but it will make a firmer weatherproof attachment.
First, smell the pigtail to see if it smells like burning plastic. Might be smart to replace it if at all in doubt. Simple things are easier to try!
Have you tried just looking inside the Tab to see if you can get a view of how/where the internal wire is connected to that fitting, and if you can spot any burned areas caused by the 'sizzling'.
Also trace where that incoming wire runs, and look at where it connects to the converter for burns. A loose connection would cause sizzling and arcing/burning.
If you're going to venture into taking things apart...
FIRST BE SURE THE POWER IS OFF, & THE BATTERY IS DUSCONNECTED.
Those three screws holding the outer flange to the Tab body would be a place to start disassembling, if you feel you can do it. You'll probably want a single-edge razor blade to cut the sealant under the flange too.
Or you could hire an RV shop or an electrician, to be safe.
If continuity is good you could plug the pigtail into home power and see if you have good voltage on the end that would plug into your rv to rule that out.
Did you say you are plugging the pigtail into the T@B? Shouldn't you be plugging the T@B 30A cable into the T@B, and that into the pigtail, then pigtail into house outlet or extension cord? Does your pigtail look like the one shown in rhyno's photo/video above?
30 Amp locking female receptacle to 15 Amp standard male. Fits the T@B to allow use of a standard 15 amp extension cord.https://www.amazon.com/Camco-55636-PowerGrip-Dogbone-Adapters/dp/B06XGX3WDT/ref=pd_ybh_a_2?_encoding=UTF8&psc=1&refRID=91GBS1F825VJQ932R8SM
30 Amp Female to 15 Amp standard male connector. This adapts the 30 Amp "extension cord" to a 15 amp receptacle. https://www.amazon.com/gp/product/B000BUU5YA?pf_rd_r=QGZXNFJ125WR97P44NVE&pf_rd_p=edaba0ee-c2fe-4124-9f5d-b31d6b1bfbee
The first I use primarily at home. I got tired of getting out the 30 Amp cord, never unrolling it, adding the second style adapter, and using a 15 amp extension cord.
The other I use at the campground. Run the 30 amp cord and adapt it to 15 amps at the pedestal when needed.
We only use the 30A cable, so have only the one adapter for home use. We've never had any issues with our 30A cable twist connector, so I couldn't see how someone could have so much trouble with making the connection. But maybe it's more of a challenge to manufacture a high quality adapter with a twist connector.
I had a 2012 T@B until last February. Last summer after 7 years of use I had to replace the 30 Amp locking female receptacle on my 30 amp cord. Connection was difficult and unreliable. Wiggling and twisting harder worked for awhile. The male contacts on the T@B looked great.
I disassembled the cord end and found damage to one of the contacts. We were on the road so a replacement end was needed quickly. Paid about $30? at Camping World. While technically not more difficult than replacing the end of a regular extension cord it was physically demanding. The water tight seals are tight.
That fixed the problem.
I can see how this particular connection design might be prone to damage for a couple of reasons. First, if the correct sequence (push completely in, twist right, screw collar down tight; unscrew collar, twist left, pull out) is not carefully followed, parts may get bent or damaged. Second, if the collar is not screwed down, there may be more tendency to bend or damage contacts if the cord gets bumped or pulled. I suspect that despite such a design intended to prevent the plug from working loose, the increased complexity may present more opportunities for wear & failure unless handled with extra care, or even manufacturing failure to meet tolerances in design.
https://www.amazon.com/dp/B07BDY3KZJ/?coliid=I27161YWBEV0XW&colid=125JQV28Y904S&psc=1&ref_=lv_ov_lig_dp_it
This replacement ring has been posted on other threads about power problems.
This is an Amazon review
This ring replaces the standard screw on ring used to make an RV shore power cord connection weather tight. The difference is that this does not require matching the threads, which invariably get cross threaded and damaged at worst, or is so frustrating that the ring isn't tightened at all, a very poor practice. As long as the receiving male portion has the necessary slots in it, all this requires is about 1/8th turn to lock into place. It's a bit of a pain to remove the old ring and replace it with this one--a little dish washing soap would make it easier, but still not easy. But it's well worth it.
Tampa FL
I struggled with the dang threads yesterday for 5 minutes - It seems no matter how much practice I get, it never gets easier. Sometimes it's a breeze, and other times it's a foreign language.
Only thing is, I can't see how one would remove and replace the ring. Dish soap, huh? We'll see.
I guess you could snip off the old one, that would reduce the work load in 1/2!
Tampa FL
