Made some upgrades to the sink and faucet of our 2019 T@b 400. Installed a new pull-out faucet on the counter top, and installed a new sink that is about 2” deeper and 1” larger diameter. The sink has a lot more usable space now. The factory sink and faucet were too awkward to use for washing large plates or pots/pans due to the limited depth under the faucet.
Overall an easy project, but it did require a few mods to make it work:
1) Cutting a larger hole in the countertop for the wider sink.
2) Modifying the drainpipe to allow for the additional depth of the sink.
3) Drilling a hole in the countertop for the faucet (after making sure there was enough clearance below).
4) Moving the upper hinge on the left-side cabinet door lower due to the new sink being wider at the bottom. (Did not anticipate this, but it actually worked out just fine.)
Faucet: Bar & Prep Sink Faucet with Magnetic Docking Sprayer, Pull Out Bathroom Faucet in Brush Nickel, Wet & Mini Bar Faucet https://www.amazon.com/dp/B07MDVYCCG/ref=cm_sw_r_cp_api_i_PQ4NFbTKTFHA5
465 18 Gauge Stainless Steel Kitchen Ensemble (Bundle - 4 Items: Sink, Basket Strainer, Sink Grid, and Cutting Board) https://www.amazon.com/dp/B00JV6R8P4/ref=cm_sw_r_cp_api_i_PR4NFbKA0THPV?psc=1
2014 Audi Q7 TDI
2014 Audi Q7 TDI
Can you please expand on how you did a couple of things?
How did you create the new hole pocket in the door to accommodate the lower hinge?
How did you shorten the black vertical drain pipe to accommodate the lower drain?
This is a great mod. My wife is psyched to see it happen in ours.
The hole in the cabinet door for the pocket hinge was made using a 1-3/4” (correction: 1-3/8”) forstner drill bit. It allows you to drill a flat bottomed hole...without going completely through the door!
Cutting the black ABS drain pipe was a bit tricky because of the tight location, but I was able to use a hacksaw blade with a stubby handle. I had to cut from both sides of the pipe until I made it completely through.
The counter top is standard laminate over plywood. I used a 1-3/4” (correction: 1-3/8”) forstner drill bit to drill the hole for mounting the faucet. It made a super smooth hole with no chipping of the laminate. To cutout the (larger) hole for the sink, I used a jigsaw with a fine toothed laminate blade which also cut smoothly and left no chipping.
Looking at the faucet (arrived today!) and the existing hinge pocket, I think a 1 3/8" bit would be more appropriate if folks were to buy one for this project.
https://www.lowes.com/pd/Kreg-Concealed-Hinge-Jig/1000422553?cm_mmc=shp-_-c-_-prd-_-tol-_-bing-_-lia-_-129-_-benchtoptools-_-1000422553-_-0&placeholder=null&msclkid=b0a46b7a4836169900a734d8d9d1120f&gclid=b0a46b7a4836169900a734d8d9d1120f&gclsrc=3p.ds
Brad.
Concord, NC
My sink arrived yesterday. Thanks again for this post.
Did you secure the sink to the countertop in some manner, or just rely on the snug fit in the hole and the stiffness of the drain plumbing to keep it in place?
The tube to elbow interface is loose, so you'll need a thick adhesive. I used 3M 4200.
