Hello T@B 400 Owners,
Has anyone removed bathroom sink and cabinets to turn into full wet shower?  I don't need a sink in the bathroom where there is sink in the kitchen just four feet away.  I need a wet shower that I don't have to pull an ineffective curtain around to stick to me while I'm showering.
Thank you,
Melanie
                1 ·
As you can see, the factory covered this section where the sink was supposed to go with a plain sheet of pebble finished plastic like panel that is water proof, and used in residential shower enclosures. The bump out at the bottom, covered by the shower pan, covers the black tank and plumbing run areas (Black tank wash, outside shower, etc.). So you can not eliminate it. The plywood strip is the point the blank covering panel would be attached. So you gain around 4 to 6-inches in the sink area, and less on the upper cubbies, not the entire space to the trailer wall.
The issue with eliminating the shower curtain is going to be a challenge, as the shower pan is installed after the walls, which are finished birch plywood. You would need to seal the wood with a good clear marine finish, that would seal the wood (not varnish or a home water based finish) with a synthetic polymer finish.
Then you would need to caulk the seam between the wall and the shower pan.
That said, the upper cupboard covers the tank vents, and the exposed wall is the inside of the Azdel side wall, with a inside covering thst is not water proof, so this would need to be covered, which could be done like my washroom was done, with a shower stall panel installed up to the ceiling at the same location, covering the plumbing and vents. This would need caulking, and screwed on, so it can be removed to service the pipes behind, if an issue came up.
Then you need to do something about the door, which is outside the washroom wall a d would need a weather seal to keep the water inside, and modify the bottom of the door wall to slant inside to drain water back in the shower pan.
We discovered a better solution to prevent the clinging shower curtain. Whilst showering, shut the ceiling fan vent, so it blows air down at you. We also added some magnets to weight the bottom of the curtain, so it hangs straight down better. The fan blowing down, pushes the shower curtain against the walls, no clinging on you. After the shower, witch the fan to exhaust (opening the vents) and five minutes or so later, after moisture is gone, switch fan back to blowing down to dry the shower curtain, another five minutes or so, then put it away.
Sounds complicated, but actually easy to do, and the curtain keeps the water off the walls, and into the shower pan. The upper cubbies are nice, to hold towels and shampoo, etc. and is above your shoulder height, so the few inches you would gain my eliminating them would not be worth the work. You could reduce how far the protrude into the space and make just slightly proud of the blank wall covering.
If the shower curtain is sticking to you, then change the fan settings like @Denny16 suggested...makes a huge difference. If the exhaust fan is on and in the 'open' position, it will suck the curtain towards the center and all over you...but if you put it in the 'closed' position, or just turn it off, the curtain stays at the perimeter of the shower and I find works great.
I get that everyone likes what they like. I personally find the factory setup easy to use and really quite nice. For me, not having people spitting into my kitchen sink is more important to me than a few extra inches of shower space gained by removing the bathroom sink.
Southern California
Full-timer since 2019
