I know I was talking big a few weeks ago that I am going to be upgrading myself to a 2021 T@B, but I have now decided to stick with the T@B I have. The big reason? The dealer told me that if I were to order now (that was beginning of October) the new T@B would not be ready until at least July! Not interested in making a mid-season switch, I am now working on getting some new mod cons ready for next year.
Here is my question. I just bought a Dometic CF18 12V compressor fridge. I bought this model because it fits in the space under the counter without sticking out (my T@B has no built in fridge, up until now I have used a Yeti cooler). This model is 12V DC only and does not offer a 120V regular plug. Most of the time I am boon docking and have a 120W Zamp solar panel (and am looking to upgrade my battery for next year but that's a whole other discussion), which will probably work out fine, and I can always add more solar power. My T@B does not have an Alde either, so my electrical needs are just the water pump, a bit of fan use, some lights and the parasitic draw of the carbon monoxide detector. I am using the amp usage charts that have been posted over the years to help me figure out how many amp hours I will need once the fridge is in the mix. By the way, the fridge is rated at 0.9 amp hours.
Okay so finally here is the question! Sometimes I do camp at sites with electrical hook-up and when I do, will I be able to use the 12V fridge - plugged into the 12V receptacle, and with shore power will it just run without having to monitor the battery? I don't use electrical hook-ups very much so this is kind of twisting up my brain. Does the power go through the converter and right to the 12V receptacle or does it route through the battery? Do I need to keep the battery cut off on or should it be off when I am in this situation?
In the spring my dealer is going to install a hidden 12V receptacle so I can plug in the cooler without a big wire running across my counter. Is there anything special about that that needs to be considered (my T@B dealer is good and the technician knows his stuff).
2021 T@B 400 Boondock Solo
0 ·
Just make sure the tech does not wire the frig directly to the battery.
Dometic CF18
2019 320 Boondock Edge - Sold Jan 2022
One side of the cooler was set as a freezer at 7 degrees and the larger section was set to 39 degrees. The white line shows the freezer temp over 24 hours. The orange bars are the corresponding current draw over that period of time. The average draw was over 2Amps/Hour.
The next day, same conditions, I set both sides of the Dometic to 39 degrees. The current draw drops to about 1Amp/Hour
Hope this helps...
The plan is to try out the fridge with my current solar and battery set up to see where it takes me, and once I have an idea of power consumption then I will invest in a new battery plus any accessories. Two 6V batteries are not an option for me, they just add too much weight (I drive a Ford Escape and do not want a bigger car).
I want to thank Crab T@B for the info. It makes me feel confident that my 18L Dometic with no freezer compartment should in fact come in at around 0.9 Amp/hour as the manual states.
