I'm a bonehead...forgot to bypass the Alde when putting in antifreeze!!
[Deleted User]
So I know better than to put antifreeze in the Alde, and I did it correctly last year, but this year I somehow was a bone head and forgot to flip the bypass lever (2019 T@B 400). I'm draining it from the Alde now. Glad I bought double amount of antifreeze. I guess its ok until I flush it out good next season with fresh water right? Its ok so long as I don't use the Alde at all right? I won't be using the camper until Spring, so I guess I'm ok? Just looking for some reassurance from the forum I guess. Man, I'm annoyed with myself!
It won't hurt anything. It might be an issue if you were going to run the Alde for cabin heat while winterized, but it sounds like this is not the case. RDWHAHB!2015 T@B Max S (320)
GREAT!!! Thanks!! I wasn't planning to use it at all, so that's good!
Yes, just make a note in the TaB to remind you next spring to do a flush out of the Alde water heater system, and Flo tank.
Denny! You must know me! Haha. I will definitely need to do that. I'm going to tape a note to the alde panel!
Good, I know I would need a note..
- 916 Introductions
- 72 Teardrop Groups & Links
