Has anyone downsized their 15" Tires to a smaller diameter?
tinglebellstinglebells Member Posts: 14
edited September 2022 in Trailer & Towing
We have a 2019 T@B 320 S Boondock Edge with 15" wheels running 235/75R15 (28" diameter) tires.  We are wanting to lower the overall height about 4" when we replace our tires.  We are wanting to fit into a standard garage without partially deflating the tires each time.  Has anyone downsized their tires yet and if so, what size is your new replacement tire?  At the bottom is an email from DEXTER AXLE that discusses the extra spin caused by smaller tire.  Below is the chart for 15" wheels from https://tiresize.com/calculator/
Tire Size Calculator Chart for 15" Wheels
20" Tire Diameter
105/70R15 = 20.8X4.1R15
21" Tire Diameter
115/70R15 = 21.3X4.5R15
125/70R15 = 21.9X4.9R15
165/50R15 = 21.5X6.5R15
195/45R15 = 21.9x7.7R15
22" Tire Diameter
125/80R15 = 22.9X4.9R15
145/65R15 = 22.4x5.7R15
155/60R15 = 22.3x6.1R15
165/60R15 = 22.8x6.5R15
175/55R15 = 22.6x6.9R15
195/50R15 = 22.7x7.7R15
22X8R15
22.5X4.5R15
245/40R15 = 22.7X9.6R15
275/35R15 = 22.6x10.8R15
23" Tire Diameter
135/80R15 = 23.5X5.3R15
165/65R15 = 23.4X6.5R15
175/60R15 = 23.3x6.9R15
185/55R15 = 23x7.3R15
185/60R15 = 23.7x7.3R15
195/55R15 = 23.4x7.7R15
205/50R15 = 23.1x8.1R15
205/55R15 = 23.9x8.1R15
225/45R15 = 23x8.9R15
225/50R15 = 23.9x8.9R15
295/35R15 = 23.1X11.6R15
24" Tire Diameter
135/90R15 = 24.6X5.3R15
155/80R15 = 24.8X6.1R15
175/65R15 = 24x6.9R15
185/65R15 = 24.5x7.3R15
195/60R15 = 24.2x7.7R15
205/60R15 = 24.7x8.1R15
225/55R15 = 24.7x8.9R15
235/50R15 = 24.3x9.3R15
24X4.5R15
24X5R15
24.5X8R15
245/50R15 = 24.6x9.6R15
345/35R15 = 24.5x13.6R15
25" Tire Diameter
165/80R15 = 25.4X6.5R15
185/70R15 = 25.2x7.3R15
195/65R15 = 25x7.7R15
195/70R15 = 25.7x7.7R15
205/65R15 = 25.5x8.1R15
215/60R15 = 25.2x8.5R15
225/60R15 = 25.6x8.9R15
265/50R15 = 25.4X10.4R15
275/50R15 = 25.8x10.8R15
26" Tire Diameter
205/70R15 = 26.3x8.1R15
215/65R15 = 26x8.5R15
215/70R15 = 26.9x8.5R15
235/60R15 = 26.1x9.3R15
245/60R15 = 26.6x9.6R15
26X10R15
26X10.5R15
26X11.5R15
26X6R15
26X7.5R15
26X8R15
26X8.5R15
295/50R15 = 26.6x11.6R15
27" Tire Diameter
205/75R15 = 27.1x8.1R15
215/75R15 = 27.7x8.5R15
225/70R15 = 27.4x8.9R15
255/60R15 = 27x10R15
27X10.5R15
27X9.5R15
27.5X4.5R15
295/55R15 = 27.8X11.6R15
325/50R15 = 27.8x12.8R15
E78-15 = 27x6.5R15
28" Tire Diameter
225/75R15 = 28.3x8.9R15
235/70R15 = 28x9.3R15
*235/75R15 = 28.9x9.3R15* (what I currently have on the T@B320 BD)
245/70R15 = 28.5X9.6R15
255/65R15 = 28.1x10R15
275/60R15 = 28x10.8R15
28X10.5R15
28X11.5R15
28X12.5R15
28X13.5R15
28X4.5R15
28X7.5R15
28X9R15
DEXTER AXLE
Mr. Tingle,
I didn’t see your axle size stated. If it’s a 10” drum or smaller the 14” wheel will fit without issue. As for your question regarding the tire size affecting the bearings. The minimal change in rolling radius will not have an effect on bearing life or heat.
Dexter would always suggest following regular maintenance to ensure long product life.
https://www.dexteraxle.com/docs/default-source/default-document-library/light-duty-maintenance-schedulee47a839d2ba463c18d7aff64007a4014.pdf?sfvrsn=30dee048_0
Kind regards,
Mark Nave | Market Manager
Dexter – Corporate Headquarters
mnave@dexteraxle.com
direct tel: (574) 295-7888 | cell: (574) 370-2661
2900 Industrial Parkway East, Elkhart, Indiana 46516, USA
fax: (574) 000-0000 | main tel: (574) 295-7888
a DexKo Global Company  ■  Together is Better
    falcon1970falcon1970 Member Posts: 758
    I suspect that would add some level of stress to the wheel bearings.  I wouldn't think Dexter engineered the bearing for the higher speeds you would incur.
    What do you hope to accomplish with smaller wheels?
    You could replace the 15-inch wheels with the stock 14-inch wheels that come with the non Boondock version.  But why pay extra for higher ground clearance and then lower the trailer back down with smaller wheels?
    Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,557
    Is this to help get the TaB into your garage?
    DougHDougH Member Posts: 1,110
    edited November 2020
    Some folks go to smaller rims, mount higher sidewall tires, and vary the inflation to manage traversing interesting backwood pathways?
    tabiphiletabiphile Member Posts: 426
    The difference in height at the step is only one half of an inch....the aspect ratio of most 14 and 15 inch tires is the same so the only change is the wheel diameter. Is it worth the trouble of making the change for half an inch?
    If you are using a tire size calculator be sure to take into consideration the availability of tires that are suitable for trailer use...the side wall characteristics and load ratings are not the same as for standard vehicle tires.
    I could see mounting the original non Boondock wheels to get the road tires vs the off road tread for a smoother ride for the trailer whilst going down highways.
    I have considered this also, as I have both sets of wheels, but on the TaB 400, both wheels are 15-inch.  However, the sidewall height is a little less on the 15-inch road tires vs the more aggressive tread AT tires used on the Boondock axle.
