I have flushed and cleaned the black tank in our TAB 400 several times and I can't get the black sensor panel to go to empty. Grey and fresh are working as they should.
My question is: would a wand type flusher down the toilet clean them? If so, where are they located on the tank? Toward the front, driver, passenger, or rear?
Jeff & Amy
Now in Manistee, MI
0 ·
Jeff & Amy
A frame grab from a video of the factory floor shows a 400 before the walls are attached. The wall side of the black tank is flat and flush with the outside wall, no sensors. My guess is that they are not mounted in the forward side of the tank either, as that side seems to be flush against the bulkhead between it and the Cool Cat.
Sorry this doesn't help much. Maybe you could rig a mirror on a stick, angled like a dental mirror, put it down the toilet and have a look. If you don't want to do that, I suggest you will find the sensors on the passenger or rear sides. But, if you are pressure washing the tank, why not do the whole thing?
Best I can get it to is a "Good" (2/3) reading on the See Level, never less even when I know it is completely empty.
Towed by 2019 Ram 1500 Rebel 5.7L Hemi 4x4 Crew Cab
Jeff & Amy
it works for us anyway, LOL
Jeff & Amy
2025 Toyota Tundra / Nashville, TN
