So off we go on our first travels of the year (Indiana & Kentucky). Trailer/car is packed and hitched up. Wrap the 7 pin cable once around the tongue jack loose enough for turns but not too loose. Drive for an hour then stop at a rest stop. Walk back to check out to see if everything is looking ok with the trailer and discover that the 7 pin cable has been cleanly cut in half. Can't believe my eyes. Fortunately it is daylight because tail lights are not working. And the brakes did feel a little off. Figured the trip is over, but started calling around and found a company that sells horse trailers at the next exit. They took a look and said this is a fairly common problem when the 7 pin cable drags on the pavement at highway speed. He fixed it up with a new 7 pin connector, charged me only $35 and off we went. Losing maybe an hour of time. The mechanic says he suggests using a bungee cable to keep the cable from getting too loose.
Turned out to be a great trip with a shaky start.
2016 Max S
Kalamazoo Michigan
Your horse trailer dealer stop was inspired! Good job.
2016 Max S
Kalamazoo Michigan
2016 CS S, 2008 Toyota Tacoma
Somerset, VA
Adventures: 58 Nights: 405 Towing Miles 50,180
Does anyone know how long the wiring/7 pin plug extends past the Hitch? I have a 7pin connection on the bumper and another in the bed.
I have a Ford truck with a 7 pin male connection on the bumper and another in the bed near the tailgate. I was wondering if the trailer wiring might reach the one in the bed.
I have not pulled a trailer with a 7 pin in a while so I went out to test the outlet on the bumper yesterday. It was dead of course and after further examination I discovered the wiring harness (the female end)was disconnected from the socket behind the bumper and the inside of the housing was half filled with dirt.
I must have pulled it loose dragging the bumper over a water bar at some point.
I gave the female end under the truck a quick test and it was live so everything should be fine after it is cleaned.
This made me wonder if I could reach the plug in the bed as its in pristine condition, being better protected.
Glad I checked before going to pick-up the new camper.
