Hi All,
I've preordered our BMV-712 battery monitor & Progressive HW30C (interior) power monitor for our Tab 400 (due to arrive this spring!), and had some questions I was hoping the experts here might be so kind as to help share their expertise on:
- What brand/model are the batteries in the 2021 Tab 400?
- What's the absorption voltage on your solar controller (MPPT 75/15) configured to?  It looks like 14.4V is the default, but there's flexibility to modify this via the Bluetooth app based on what our battery actually calls for.  I'm curious if nuCamp tweaked this for the batteries or left it at default?  And if they left at a default different than our batteries spec, did you update it?
- What did you set your BMV-712's 'charged voltage' to?  According to Victron (
 https://www.youtube.com/watch?v=4ReljfO3k6M)
https://www.youtube.com/watch?v=4ReljfO3k6M) this should be set to 0.3V below absorption voltage for solar systems (14.4 minus 0.3 = 14.1V if we're using 14.4V as the absorption voltage in the MPPT 75/15).  Which is quite a bit higher than the 0.3V below float voltage specified for non-solar setups.
- Similar question on the BMV-712 - they also recommend leaving the tail current to 4% and the Peukert exponent to 1.25 for generic lead-acid (though if the spec sheet for the batteries used on the Tab 400 specify it more explicitly, we could update it..).  Ditto for charge efficiency factor (default is 95% but if battery specs provide a better #, we could use it..).  Have any of you played with this value?
- For installing an internal surge protector/power monitor, is the 30A 120V feed into the camper easily accessible under the bed (driver-side panel), where the Nautilus and Alde live?  I'm considering wiring the HW30C in this area and routing the readout panel to the Nautilus compartment for easy viewing from exterior during setup.  But I haven't seen any photos of where the power actually feeds into the trailer.  On the exterior it's just to the left of the Nautilus but I can't tell if it would enter under the bed or under the fridge(3-way)/wardrobe, and how it routes to the converter (under the kitchen cabinets on the other/passenger side) from there.  Maybe it would be easier to install the power monitor somewhere behind the converter?
Thank you for any/all advice!
Check out my install:
https://tab-rv.vanillacommunity.com/discussion/11078/hardwired-hughes-power-watchdog-in-2021-t-b-400
Installing behind the drawer below the wardrobe closet is a great location too. I didn't cut any factory wires.
I disconnected the wire from the back of the 30A Plug on the outside of the 400, and used that for the load side of the EMS.
I then used a new short piece of 10 gauge copper wire (orange covered wire same as the factory) from the plug to the line side of the EMS.
Can be restored to factory in about 5 mins, with nothing but a screwdriver.
