simple solution to draft from air conditioner
sbhtennis
Member Posts: 69
The last time I went camping ( November) I noticed that sitting on the bench under the air conditioner I felt an awful draft coming thru the air conditioner unit. I have a 2016 Tab Max S 400.. So today I fixed it ( I hope) with a very simple solution.
I cut a piece of that shiny insulated fabric ( a friend gave me some) and put a couple of velcro hooks on each corner and on the T@B air con frame
and voila it covers the outside perfectly. Of course it will only go on once I am parked and this is just a winter thing..
and voila it covers the outside perfectly. Of course it will only go on once I am parked and this is just a winter thing.. 4
When I first bought my 320, gazing in bliss at the interior, by eye was blinded by a bit of sunlight that was sleeping through a crack between the air conditioner & the beauty trip that surrounds it.
My first modification was was to remove the trim and cram insulation around the air conditioner in its opening. The beauty trim covers it. Since then I have added a plexiglass cover, similar to what you have done, but sealed with window/door seal and J bolted to the louvers. It is sealed tight, and withstands Hwy speeds.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback1 -
@4ncar, your photo may resolve it, or I may simply be mistaken in how you closed off the air/light entering your trailer, but can you clarify where and how much insulation you crammed around the air conditioner?
If you stuffed the area on both sides of the air conditioner, and assuming it is the same/similar to the Danby A/C, then aren't you cutting off the Exterior Air Inlet that is located on at least one side of the A/C? I looked at the Danby owner's manual and it depicts the inlet on the filter opening on one side, but I cannot specifically recall when I removed my Danby A/C in the past if there are air inlets on both sides.
If you only closed off the area immediately behind the decorative molding around the interior face of the A/C, then that isn't an issue, but I would think you would have problems (while running the A/C) if you filled those side voids full of insulation.2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
I did the same mod without the center bolt. I was concerned I was pushing the j-bolt too far into the screen behind the vent. I ended cutting a little bit off of the curved end of the j-bolts.2019 Tab 320 CSS, 2019 Ranger TV, OH1
@4ncar thanks.Here's my mod. It was easy and cheap. I used that plastic board that looks much like cardboard and some of those 3M stick on plastic hooks. If I can figure out a way to add one on the right side where I slide it in, I may be able to leave it on, but for now, this is only for parking.I may see if I can make something more for highway speeds but for now, when parked I can cover the vent, but I still feel cold air coming in. I may need to add some bubble wrap, foam or wall insulation inside the trip as well to keep the draft out. I think it's affecting mythermometer/sensor on the Alde heater unit quite a bit.
2018 T@B 320S / 2024 Chevy Blazer RS AWD / Phoenix, AZ1 -
Good idea Reenie0
@ReenieG: previously, I mentioned how I used fiberglass insulation to plug the gaps around the ac unit. This should help in the cold air infiltration, I’ll try to snap a pic of mine tomorrow. I also used sticky backed window/door insulation tape around my plexi cover, it helps to seal the plexi tight to the grill. You can see it in the pic above, it looks like a gray border.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
